Neptune and the Quad Stage Controller?
Old Sep 13, 2006 | 08:55 PM
nebulight's Avatar
Default Neptune and the Quad Stage Controller?
I know that Neptune can control this, however, I was curious to see if you can have two maps, each having two stages. For instance a race gas program with low and high boost setting, as well as a pump gas with low and high?
I would like two stages: one for lower gears for traction and another for higher gears for more power. Then I would like to wire the AC button to change to a Race gas program, again having two maps. I wasn't sure if I could change the trigger for stages with neptune in different maps.
Old Sep 13, 2006 | 09:51 PM
qfast817's Avatar
Default Re: Neptune and the Quad Stage Controller? (nebulight)
i know you can jump the ecu to upload the 2nd map with neptune
Old Sep 14, 2006 | 04:52 AM
tepid1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight &raquo;</TD></TR><TR><TD CLASS="quote">I know that Neptune can control this, however, I was curious to see if you can have two maps, each having two stages. For instance a race gas program with low and high boost setting, as well as a pump gas with low and high?
In short, your answer is yes you can set it up like that.
Old Sep 14, 2006 | 05:55 AM
Turbocivic94's Avatar
with Neptune RTP you can shut 2 stages by software, with regular neptune you would have to disconect the power going to solenoids. Let me know if u need any help. I wired up mine twice
yes you can use a/c buttong for race gas. I love this feature
Old Sep 14, 2006 | 06:29 AM
93supercoupe's Avatar
Default Re: Neptune and the Quad Stage Controller? (Turbocivic94)
nm
blackeg
Jul 9, 2011 06:03 AM
Hondatuner88
Oct 2, 2006 06:03 AM
spoolingb20
Aug 21, 2006 10:21 PM
Nextelbuddy
May 5, 2004 10:53 PM
Spooled1.6L
Feb 4, 2004 05:40 AM
