Needed TD05-18G turbo Parts. *Look*
I am looking for some Turbo parts for my 1996 Integra GSR with a TD05-18G Greddy Turbo Charger I need these parts to complete my kit.
The parts do not have to be from GReddy as long as they will work with my 18g turbo. Please help me find these parts asap.
From GReddy integra GSR parts list
15) Oil Pressure line (1200mm)
16) Banjo Union
17) Copper Washers 10Q (1.0mm)
18) Three way fitting 1/8 NPT *HAVE*
19) Straight Union Fitting 1/8PT - 1/8PT *HAVE*
20) Straight Union Fitting 1/8PT - 1/8PF *HAVE*
22) Oil Return Flange Tube (engine Side)
23) Flange (looks like a Oval with oOo holes)
24) Vacuum hose (blue) 5Q x 1300mm (Actuator pressure line)
25) Rubber hose 8Q x 450mm (Water by-pass hose)
27) Rubber hose 16Q x 380mm (oil return hose)
30) Rubber hose 80Q x 80mm
42) Gasket Down pipe Adapter 60Q triangle
44) Gasket oil return Flange tube (Quantity 2)
45) A/C line Bracket
47) Thermo-cloth 100mm x 1000mm sheet
The items are listed as they appear on the GReddy 96 Integra GSR turbo kit parts list.
Thank you for your time.....
[Modified by 94mugenintegra, 12:07 AM 8/20/2002]
16) Banjo Union
Re: Needed TD05-18G turbo Parts. *Look* (94mugenintegra)
Dude most of these parts can be found at discount auto parts or your local parts store. I wouldn't recommend that oil return flange with all those holes because two of those holes are just two more excuses for an oil leak, Get a threaded hose nipple about 3/4 to an inch in diameter (or whatever the oil return hose size is)about 3 to 4 inches long, I got mine from Central auto parts. Threaded so you actually screw it into your oil pan, If your gonna use steel braided with compression fittings like the drag kits then maybe you can find something similar (with screw on nipple instead of push on).
Otherwise items 18, 19 20 22 24 25 27 30 47 can be found at your local parts store some even from lowes home inprovement (the brass NPT stuff) hope this helps.
Re: Needed TD05-18G turbo Parts. *Look* (maddskilzz)
I will check one more place here in town (NAPA) hopefully they will have all that i am looking for, otherwise i have no idea where to get this stuff.
I will let you know what happens Tonight
They had 18,19 and 20 and told mt to check one more place in town tomorrow (they were closed) so i will do that after work and post up what i am still looking for.
