need sum quick help
Old May 18, 2004 | 08:08 PM
lsracer27's Avatar
Default need sum quick help
i was just wondering if its ok to have my oil feed and return at my turbo both pointing outward towards my block and rad. instead of straight up and down because thats the only way i can make it work...because the bolts on the exhaust side of my turbo will not break loose they are rusted too bad ..but the turbo is still in good condition
Old May 18, 2004 | 08:24 PM
Pengo's Avatar
Default Re: need sum quick help (lsracer27)
for feed it shouldn't be too big a deal since that's pressurized, but for return, i must assume u mean the flange ends up pointing out towards the rad before going down to the pan? generally you want the return to be as straight down as possible since it's gravity dependent. i guess if it has a slight downward angle and then went straight down and to the pan, it might drain fast enough and not back up, but if it's perfectly level....i dunno, i'm thinkin it may have some problems. post pics, it would help alot
Old May 19, 2004 | 08:03 AM
lsracer27's Avatar
Default Re: need sum quick help (Pengo)
ok thanks ill get sum pics up today
Old May 19, 2004 | 08:06 AM
FwdCivicHatch's Avatar
you'll probably have problems........most likely smoking oil from the turbo
justYncredible
Apr 24, 2012 06:45 PM
b15ser
May 16, 2010 08:34 AM
speedfoxracing
Jan 18, 2010 03:14 PM
Vp Special K
Jul 25, 2005 06:15 PM
djickabod
May 9, 2004 02:40 PM
