need sum help with sleeve questions
Old Dec 15, 2010 | 04:14 PM
98corbeau coupe's Avatar
Default need sum help with sleeve questions
ok so this is my setup
gsr block and head
head will b ported and polished
gunna have it bored to 81.5mm
full supertech valvetrain
gsr exhaust cam
ctr intake cam
cp 9-1 pistons
eagle rods
3076 turbo
ramhorn
im shootin for 500whp on pump and 600 on c16
what r your recomendations for sleeves?
should i b ok with stock sleeves if i use a block guard?
or should i just send it out to golden eagle for a set of sleeves?
thanx in advanced
Old Dec 15, 2010 | 08:53 PM
dantamparacer's Avatar
Default Re: need sum help with sleeve questions
I would get it sleeved. It will last alot longer than just stock sleeves. 600whp is gonna have a lot of cylinder pressure and its not pretty when you crack a sleeve. A buddy of mine just finished his car with stock sleeves and made about 680 for about 5minutes till it split a sleeve.
Old Dec 16, 2010 | 11:31 AM
Golden Eagle's Avatar
Coast t coast G.E. lets you boost the most.
PM for special pricing I will hook you up.
MonstroniuM
Dec 13, 2007 07:20 AM
KeyserSoze
May 14, 2005 09:40 AM
96cxt
Oct 22, 2002 03:12 PM
MikeySpec
Nov 23, 2001 07:50 PM
Trajic
Aug 22, 2001 02:35 PM
