Need some problem solving help (no power)
Old Apr 19, 2006 | 09:25 AM
Boilermaker1's Avatar
Default Need some problem solving help (no power)
I know the scan sucks... here's the vitals
106.7 HP at 5693 RPM. It made 122.2 lb-ft at 3689
This is w/ a GT28R at 6 lbs..... We know something's not right.
The following have been ruled out...
Boost leak
Vac leak
heat soak
tuning (it just got tuned)
inlet restriction (only gains .8 HP w/o filter)
bad plugs (pulled on the dyno)
No CELs
Theory at the moment is that because the car was running rich during the week between installing and tuning (baseline AF when we started was in the 9's). The Cat fused. Anyone want to buy this? or should I be looking for a bigger issue.
The car makes and holds boost from 2400 to redline.
Old Apr 19, 2006 | 09:41 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Need some problem solving help (Boilermaker1)
how is the emgine internally?
good compression no leakdown?
Old Apr 19, 2006 | 11:23 AM
Comp/leakdown hasn't been checked. It makes no funny noises, oil and water are both clean, catch can is dry. Shop said it sounded fine and ran well without any signs of issue.
Old Apr 19, 2006 | 12:47 PM
b00sted_hatch's Avatar
Little Hercules
Default Re: (Boilermaker1)
it might just be the dyno..ive seen this happen to my buddy zol with his boosted civic..it out down 201whp on the bad dyno( we didnt know it was bad)and then went to another shop and put down 523whp..have them chekc the dyno
Old Apr 19, 2006 | 12:53 PM
I will... but the thing is that the torque plot is the same as what the car feels like, it takes off, but then just gives up. I'm going to check the manual for the VTEC solenoid test too. Make sure its crossing over, and pull the cat off to have a look.
MindLess311
Jun 10, 2011 04:45 PM
StolenTeg
Sep 26, 2010 12:04 PM
batboyvaj
Jun 8, 2009 12:26 PM
craigbrk
Oct 22, 2006 08:44 AM
DC2R714
Aug 23, 2002 05:31 AM
