good CHEAP place for turbo gaskets?
I have ALL the peices for my turbo project but 2 gaskets...from the manifold to turbo....and the turbo to downpipe. for a t3 turbo.
Re: good CHEAP place for turbo gaskets? (quik sol)
i would like to know also, but i only need a 5 bolt gasket for turbo to downpipe.
You can get the manifold to turbo gasket from projectDC2 her on honda-tech.
1 Post
Re: good CHEAP place for turbo gaskets? (redDAinteg)
Really if your components are new (with nicely machined level surfaces) you do not need gaskets in those positions. I personally spray a good coat of copper gasket spray on each surface, give it a moment to become tacky, and assemble.
No problems thus far.
Location: The Village Hidden in the Leaves: Seattle, WA
maybe try atpturbo.com
for turbo to downpipe, you can buy this gasket material from napa for pretty cheap. it's like a big sheet (12x24) for like 15 or 25 bucks. but you'll come to find that most ppl don't use a gasket between turbo and downpipe.
sorry was out of town, well my friend tried making his own gaskets out of gasket material and it didn't work to well, and my manifold and turbo are used. so I would prefer gaskets, I was looking for like a copper gasket I had for my 16g setup.
Re: (quik sol)
grab an inlet gasket from somewhere like atpturbo. downpipe gasket is not needed. inlet gasket may not really be needed either but i dont think you should risk an exhaust leak prior to the turbo. it will hurt spool time and overall performance.
if you really want a downpipe gasket you can get one here http://www.roadraceengineering...s.htm scroll all the way to the bottom. inlet gasket $8, dp gasket $15.
mmmtrbolude93
06-29-2007 07:46 PM
