Boost leak? Dyno chart included
Old Sep 24, 2010 | 07:47 PM
StolenTeg's Avatar
Default Boost leak? Dyno chart included
From the way the power climb, look like i have a boost leak somewhere? the power never flatten out and keep climbing until redline?
Graph is in MPH 8000 redline
Old Sep 25, 2010 | 05:05 AM
blackeg's Avatar
Default Re: Boost leak? Dyno chart included
what is the torque curve look like?. if the tq holds flat then it could be just the turbo/cam setup in your motor. (my power keeps going up until around 8000 where it holds flat till 9000.
also, can you datalog with your management?
Old Sep 25, 2010 | 05:19 AM
StolenTeg's Avatar
I dont have the torque reading, something was wrong with the dyno
Old Sep 26, 2010 | 06:16 AM
StolenTeg's Avatar
The A/F also leaned out into the high 12 from 7-8k, i dont know if that indicate a boost leak?
Old Sep 26, 2010 | 06:32 AM
spectacle's Avatar
looks fine to me.
if you're worried, run a boost leak test
Old Sep 26, 2010 | 11:18 AM
StolenTeg's Avatar
This is a dyno for a LS turbo set-up on the same dyno, the power peak and flatten but on mine which is ls-vtec it just climb and never flatten out
Old Sep 26, 2010 | 12:04 PM
welfarepc's Avatar
it just means your motor breathes better at high rpm.
torque is holding flat, and there fore your HP keeps climbing.
the HP will only plateau if the torque falls off
Freshdot
Oct 6, 2014 07:45 PM
spectacle
Sep 5, 2010 12:24 PM
ImPuLsIvE
May 30, 2008 10:05 AM
craigbrk
Oct 22, 2006 08:44 AM
TheYellowDart
Mar 18, 2005 10:18 PM
