Need Some Hose Help!!!
Old Oct 16, 2005 | 12:15 AM
Dan_the_MaN's Avatar
Default Need Some Hose Help!!!
I am looking for a staight reducer hose for my turbo. I need a hose that connects between the turbo outlet and the intercooler pipe. The one that came with the turbo ripped. Now, as your already know, the turbo gets very very hot and there is a lot of pressure coming out of it. I am running at 8psi.
I was looking at Samco Silicon hoses, but they have a max operating temp of 356 degrees. Is this enough or do I need something thats goes up to 500 degrees? What do you suggest? Thanks guys.
Old Oct 16, 2005 | 05:33 AM
NJIN BUILDR's Avatar
Default Re: Need Some Hose Help!!! (Dan_the_MaN)
Silicon is what you need.I have seen some of these rated up to 600 degrees but I don't think it matters.The compressor side doesn't get that hot.If your inlet air temp is 300 degrees the motor will grenade before the hose melts.I've used these with success. http://www.atpturbo.com/Mercha...L-TRN
Glenn
Old Oct 16, 2005 | 05:53 PM
Default Re: Need Some Hose Help!!! (NJIN BUILDR)
Thanks. So the samco hose, rated at 350 degrees should be enough for my purposes? Can anyone else chime in?
Old Oct 17, 2005 | 10:02 AM
bump
Old Oct 17, 2005 | 02:37 PM
TurboCoop's Avatar
yes its fine, just dont get rubber ones from home depot
djnikko
Jan 7, 2015 05:15 PM
Hondatuner88
Welding / Fabrication
Feb 13, 2008 06:56 PM
high boosted rex
Aug 24, 2006 07:03 AM
BB6-213
May 28, 2006 07:03 PM
