Need some help with S300 Boost Control
Old Sep 16, 2007 | 08:41 AM
bigbadboy's Avatar
Default Need some help with S300 Boost Control
seems that my BC is not working as it should. runs 7lbs off the WG and when ever i set the %duty cycle it goes whack. 1% duty cycle gives me 15lbs. if i try to do boost by gear anything over "0" or "1" psi of boost will automaticly try to shoot past my boost cut set at 17. anyone got any ideas? i have an Apexi selenoid valve on the S300, i have it set to Selenoid Normally closed ( which is the way i have it set up). thanks for the help
Old Sep 16, 2007 | 08:05 PM
bigbadboy's Avatar
bump
turbo boost
May 6, 2008 04:07 PM
Happyman
Sep 1, 2003 07:04 AM
311
Jul 12, 2002 01:46 PM
