need some help please car wont start using crome
Old Sep 10, 2010 | 03:58 PM
chris2003's Avatar
Default need some help please car wont start using crome
i just installed my turbo kit on my ls and i followed the crome startup guide to setup my basemap on my chip, it is the same chip that i used before i installed my turbo so i know that the chip and ecu is ok. for my fuel multiplier i have an offset of 50 and for starting offset i have tried .75 and .60 i am not sure what to do my car will not crank also for my battery offset i used the rc 440 16ohm setting because i know my injectors are 440 16ohm delphis and that is the closest option i had. does anybody have any ideas
Old Sep 10, 2010 | 04:00 PM
Pay2play killa's Avatar
Default Re: need some help please car wont start using crome
is the CEL on? is it solid?
try getting on xenocron's website if its still around and d/l a bin as a starting point and work from there or use some if its values
/edit: you say it wont even crank over? thats not an ecu problem thats something else mechanical or electriccal
Old Sep 10, 2010 | 04:04 PM
chris2003's Avatar
no check engine light and sorry let me clarify it will turn over but not crank
Old Sep 10, 2010 | 04:05 PM
turn over and crank is the same thing....
do you know if you are for sure getting fire and fuel?
Old Sep 10, 2010 | 04:07 PM
chris2003's Avatar
as far as the basemap goes i really dont think thats the problem i think it is the injectors i just to a p75 map added boost tables and retard .85 deg./lb and put the efficiancy at 120%
Old Sep 10, 2010 | 04:08 PM
chris2003's Avatar
yeah i chked for fire and fuel and i kinda tried to start once or twice but i think it is flooding out
Old Sep 10, 2010 | 04:11 PM
try turning up or down the fuel multiplier see if that helps or hurts
do you have a wideband?
Old Sep 10, 2010 | 04:16 PM
chris2003's Avatar
i have a wideband but i dont have a bung welded in yet i was gonna put the car on a trailer and take it to the muffler shop welding is the only thing i dont do on my rides (myself) should i mess with the offset or just the cranking offset also i can send you the file if you want to look at it just pm me an email address
thanks for the help
Old Sep 10, 2010 | 04:22 PM
are you using the gold firmware or good 'ol crome?
Old Sep 10, 2010 | 04:28 PM
chris2003's Avatar
free crome
Old Sep 11, 2010 | 02:03 PM
jedsus617's Avatar
they should have a map wit the 440 injectior...i bet its ur map that causing ur problem
silez
May 1, 2014 03:55 AM
mynameizstitch
Mar 17, 2012 10:55 AM
rudyndrew
Jul 14, 2010 10:14 PM
sounique
Apr 16, 2003 04:23 PM
