Need some help idenifying this precision turbo
Old Jun 24, 2004 | 11:20 PM
Rain_man's Avatar
New User
Default Need some help idenifying this precision turbo
I ordered this turbo a few months ago and never checked to confirm that I recieved the correct turbo. Before I throw it on my car, I'd like to do a dbl chk to make sure I have the right one. The Compressor cover says AR .60 and the exhaust housing says AR .63.
If the pictures aren't good enough let me know and I'll put some new ones up.
Thanks!
Keith
Old Jun 24, 2004 | 11:28 PM
Sonny's Avatar
You need to measure the inner and outer portions of both the compressor wheel and turbine wheel.
Sonny
Old Jun 25, 2004 | 12:00 AM
Rain_man's Avatar
New User
Default Re: (Sonny)
Turbine wheel diameter is 2.25 and 2.5 approx. Gonna take off the compressor cover tomorrow to get the compressor wheel diameter.
Old Jun 25, 2004 | 12:12 AM
MrBond's Avatar
Default Re: (Rain_man)
if turbine is 2.559" and 2.228" it's the T31 76trim wheel.
It can basicly be the whole precsision SC line except the the sc52, 61 or 63.
you need to measure that comp wheel more accurate. (There are about 0.05" difference between the models...)
Old Jun 25, 2004 | 02:51 AM
M.A.R.C.'s Avatar
Default Re: (MrBond)
there's an easier way to check... look inside or outside the compressor outlet... it should have a code engraved in it... like say "SC61E"... it should be right around where the coupler is that u have t-bolted on there.
Old Jun 25, 2004 | 09:17 AM
Rain_man's Avatar
New User
Default Re: (CivicRyda2k)
The compressor outlet is engraved w/ 3431E and the compressor cover on the inside is stamped w/ CCE34, so I know for sure at least that it's an E compressor cover I have.
I did my best to measure the compressor wheel and got 3.03 (77mm) and 2.24 (57mm).
Thanks for the help guys. Normally I wouldn't be so worried I recieved the correct turbo, but I bought this turbo off a formerly well regarded HT sponsor.
Modified by Rain_man at 1:52 PM 6/25/2004
Old Jun 25, 2004 | 09:19 AM
RobbieG35's Avatar
12 Years Strong
Kind of looks like a 57 trim SC34
Old Jun 25, 2004 | 09:30 AM
B18Flip's Avatar
Default Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">Kind of looks like a 57 trim SC34</TD></TR></TABLE>
yup its an SC34, 57 trim comp wheel, .60 comp housing and a .63 turbine...i had the same one
Old Jun 25, 2004 | 09:53 AM
Rain_man's Avatar
New User
Default Re: (B18Flip)
Perfect, that's what it's supposed to be, hehe. Thanks!
motoxxxman
Jun 9, 2017 06:25 PM
civic92si
Sep 19, 2010 01:36 PM
booscivic
Sep 25, 2006 07:50 PM
stizzit
Sep 6, 2004 07:20 PM
