need some direction in turbo project
Old Jan 8, 2004 | 07:23 PM
giff74's Avatar
Default need some direction in turbo project
I have a DA, that is getting a b16a1 installed this week. After my wife recovers from the shock of writing the checks, I am going to do a custom turbo with the shop that is doing the swap. I want to start out with something like 6-10 psi, if my math is correct that will get me into the lower half of the 200's at the crank, which will be fun, since this car is only a dailey driver and a once in a while autocross car.
What I eventually want to do is run about 300 bhp, once the car is for the track only. My question is, what psi should be "safe" to go up to before I start to replace internals. My next question is what are the internals that need replacing, and in what order should they be replaced?
Thanks for the help!
Old Jan 8, 2004 | 07:41 PM
vaporboy12's Avatar
sleeve a block,forged pistons and rods, are the 3 most important id say. i would say just go ahead and build the motor. if you've got the money why wait? better to be safe than sorry.
Old Jan 8, 2004 | 07:56 PM
giff74's Avatar
Default Re: (hksb18b)
I thought about doing the engine first, but sleeves, pistons and rods wouldnt really increase power by themselves since I cant up compression if I am going to turbo. Right now I just want to have more fun with the car, could I go up to 10 psi with everything stock in the car?
Old Jan 8, 2004 | 08:00 PM
vaporboy12's Avatar
Default Re: (giff74)
yes as long as the tuning is good you should be fine just dont beat on it. stock internals can handle a good amount of boost but not for long. i boosted a stock motor to 20 psi for like a month and half then blew . it comes down to tuning.
Old Jan 10, 2004 | 02:18 AM
giff74's Avatar
I know this is all subjective, but if I put on a turbo, about how much boost could I run constantly on stock everything, and not blow anything up?
Old Jan 10, 2004 | 07:16 AM
vaporboy12's Avatar
if you got a good tuner like 8 psi
delinquent
Aug 23, 2009 07:20 PM
civic_66
Nov 19, 2006 03:02 PM
moonmoney20
Jun 26, 2006 11:11 AM
EfSedanLove
Jul 21, 2004 05:48 PM
Knight2000
Jan 2, 2003 10:28 PM
