Need some advise on custom turbo for Ls motor in Crx??????
Im gona do a custom kit for a friend of mine on a LS motor in a crx. This is my first time to not install a complete kit so I need some help finding the best deal on.
1# A down pipe to fit a garret T3/T4 turbo charger if it will work on a integra Ls im sure we will have no problem with it in crx since the Ls exhaust bolt directly up.
2# I need to find a complete oil line setup (feed line. tee,return line and what ever misc ill need too)
If any body can help I have faith in H/T
Re: Need some advise on custom turbo for Ls motor in Crx?????? (Boostin Ex)
#1) 4 bolt or 5 bolt flanged turbo?
#2) What kinda of oil line setup are you looking to run? Here is the typical setup I like to recommend --
Re: Need some advise on custom turbo for Ls motor in Crx?????? (Speed PHreak)
The turbo is a 4 bolt. Sorry
The oil line kit I was hoping on going with braided stainless line for feed line, Dont really care what I have for the return line, and im just gona run a three way tee at the back of the block. I just need oil supply line and dummy senser.
You are going to have a hard time finding parts that will bolt on to that setup. There isn't a whole lot of room with an ls motor in a crx. You have to work around that damn crossmember. Looks like you need some pipes and a welder.....
Re: Need some advise on custom turbo for Ls motor in Crx?????? (tony1)
Note the signature
I think I know a place that sells a bspt to AN fitting so you eliminate #f near the block, I'll try to find the part number.
