Oil feed help....
Old Apr 24, 2004 | 12:02 PM
tolowhb's Avatar
Default Oil feed help....
Well, I began installing my greddy turbo kit today, and I am stuck on one part.....The oil feed line, now the part I am stuck on is the banjo bolt set-up (into the turbo) You need to line up the holes inside the bolt with the hole in the fitting that connects to the line. But those holes do not line up at all. The only way to line them up would be for the to be to loose, any help?
Old Apr 24, 2004 | 12:58 PM
tolowhb's Avatar
Default Re: Oil feed help.... (tolowhb)
bump
Old Apr 24, 2004 | 01:21 PM
Cruiser G's Avatar
You dont need to line up the holes.
Old Apr 24, 2004 | 02:11 PM
aw1234dude's Avatar
Default Re: Oil feed help.... (Cruiser G)
Yeah banjo fittings have a channel that runs around the inside of the circle for the fluid to flow through. The orientation of the hole on the bolt does not effect if fluid flows into the hose or not. Your alright by having the hole face which ever way.
Old Apr 24, 2004 | 05:27 PM
tolowhb's Avatar
Damn I am a dumb boost newbie . Thanks!
stackz
Feb 28, 2008 01:49 PM
Racerage1
Mar 25, 2003 09:22 PM
