Engine Management/Turbo Setup question
Old Feb 18, 2006 | 03:13 AM
jeffk182's Avatar
Default Engine Management/Turbo Setup question
Im gonna be running an Emanage with my turbo setup. When I got my kit, the kit included the Vortech FMU and the Missing Link. If im going to be running the emanage, do I still need to use the missing link and the FMU? Or is just the emanage ok? Im pretty sure I wont need the FMU anymore. Would I still need to teh Mising link to trick the MAP sensor so that it doesnt see boost? Or does the Emanage already fix that? Thanks.
-Jeff
Old Feb 18, 2006 | 12:02 PM
jeffk182's Avatar
Bump
Old Feb 18, 2006 | 02:34 PM
jeffk182's Avatar
TTT
Old Feb 20, 2006 | 12:58 AM
jeffk182's Avatar
bumpizzle
Old Feb 20, 2006 | 02:19 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (jeffk182)
u answered your own questions
Old Feb 20, 2006 | 06:49 AM
TheShodan's Avatar
Moderator
The Missing link is no longer needed with the e-manage, simply reuse your stock map sensor. You'll need the E-manage/DENSO Pressure sensor as part of the setup in order to use the system. The FMU is no longer used at all. The e-manage can take up to 660cc injectors, though the correction factor on the computer may need to be adjusted in order to function properly and the get the idle fine. Otherwise, you should be fine, but it needs to be properly tuned.
Hope that helps, somewhat..
96EKshaved
Sep 4, 2005 01:20 AM
egturbo
Oct 6, 2004 02:01 PM
Hockey27925
Jul 7, 2004 03:49 PM
DLOTYPER
Jun 2, 2003 12:19 PM
Turbo_Si
Aug 13, 2002 09:17 AM
