Need some advice.
Old Nov 4, 2003 | 06:17 PM
drvfast's Avatar
Default Need some advice.
My setup is a jdm b16 which the compression is 10:4:1. the setup that i have is a precision sc34, walbro 255 intank, vafc plan on running the hack,440cc injectors msd btm not the 6a just the regular btm. the block is stock. i plan on runing low boost like 7-8 psi daily im thinking about lowering the compression with the thicker head gasket but im not sure if i should go ahead an do that or keep the stock compression? what do you guys think? if anyone has a boosted 10:4:1 motor can you tell me how much timing did you pull at 7-8psi. thanks
Old Nov 4, 2003 | 06:42 PM
drvfast's Avatar
Default Re: Need some advice. (drvfast)
bump before leave work
Old Nov 4, 2003 | 07:08 PM
Joseph Davis's Avatar
You're running an AFC hack, and you're worried about pulling timing?
lol.
Old Nov 5, 2003 | 04:23 AM
drvfast's Avatar
Default Re: Need some advice. (J. Davis)
so you saying i can't pull any timing running the hack? i know it advances alot of timing in part throttle boost. does it advances timing that much?
Old Nov 5, 2003 | 07:29 AM
drvfast's Avatar
ttt
93civciv
Dec 4, 2007 05:23 PM
Dr. D-Series
Apr 23, 2005 05:24 AM
asianspeed
Aug 8, 2003 05:05 AM
BorderM3
Dec 30, 2002 11:40 AM
