Need Opinions
Old Apr 3, 2007 | 06:56 PM
Boostin_GSR's Avatar
Default Need Opinions
So I picked up a block for my big boost build up. The block has stock sleeves that have been bored out to 81.5mm, and there is a sleeve guard installed. I'm looking to make some monster power and would like to push 20 psi as high boost out of the block, does this seem reasonable? About how much boost would I be able to safe to run before I would blow those sleeves out? Could anybody drop down some of that good old honda-tech advice.
Modified by Boostin_GSR at 1:20 AM 4/4/2007
Old Apr 3, 2007 | 07:00 PM
Zeusfire69's Avatar
Default Re: Need Opinions (Boostin_GSR)
Are you saying that it has just a block guard, or does it have sleeve inserts? If it only has a block guard, it won't last long under high boost. But, as usual, how good your tune is will determine how long everything will last...
Old Apr 3, 2007 | 07:09 PM
Default Re: Need Opinions (Zeusfire69)
No just a block guard, no sleeve inserts.
Old Apr 3, 2007 | 07:44 PM
morgan@synapse motorsport's Avatar
the limitation of the stock sleeves arent defined at a certain psi more so by how much power the engine puts down.
how much power do you want to make, and what turbo are you using?
Old Apr 3, 2007 | 07:49 PM
Default Re: (mike@synapse motorsport)
Using a Garrett .60 trim with .63 A/R. Turbo is suppose to only be good for 490whp so as close to that would be nice. What kind of power can the stock sleeves handle, some guy in a post I had from a while back asked me why I was gonna stroke my motor when you can make 500whp on a bone stock longblock.
Modified by Boostin_GSR at 9:13 PM 4/3/2007
Old Apr 3, 2007 | 09:02 PM
Default Re: (Boostin_GSR)
bed time bump
Old Apr 4, 2007 | 12:21 AM
Looking for some answers.
BoostFedB16A
Mar 5, 2013 06:05 PM
slammedbbs
Jun 6, 2011 09:32 AM
Boostinb20!
Nov 28, 2008 08:30 AM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
The_Robster
Oct 30, 2002 02:41 PM
