need knowlageable verification of 400whp b16
Old Jan 22, 2009 | 05:16 PM
stalyun's Avatar
Default need knowlageable verification of 400whp b16
This is the setup i have being built by a shop. I need to know if 28psi is too much for my turbo and motor on pump gas. this is not a strip/track car. kinda a daily driver. Ive read people making more HP than this on pump gas. my first attempt at this i did not have a sleeved block. im looking for some re-assurance the reason my first block blew was because of catastrophic failure (#4 cylinder cracked sleeve) and it most likely wont happen again with sleeves.
at 22psi i yielded 350whp. 28psi should be 400+~whp
b16a2- darton open deck sleeves .020 over, eagle and cp setup, 9.0:1, Brian crower stg 2 turbo cams, titanium retainers, valve springs, fluidamper, FAL fan, mishimoto radiator, hasport solid mounts, D2 coilovers
obd1 tuned on ectune w/ electronic boost solenoid w/ boost by gear option
68mm throttle body, skunk2 intake manifold.
turbonetics t3/t04b .48 a/r 50trim. cast log manifold, 38mm turbonetics evolution wastegate
i know the simplest answer is to get a bigger turbo. probably a 60trim. but this is my current setup and ive spent ALOT of money getting this done.
any info/tips/advice would be appreciated.
Old Jan 22, 2009 | 08:13 PM
stalyun's Avatar
Default Re: need knowlageable verification of 400whp b16
bump for info?
Old Jan 22, 2009 | 08:44 PM
TheShodan's Avatar
Moderator
Another turbo, retune. Sorry to say that, but in your case, it is that simple. the older turbonetics used stage 2 turbine wheels. That's why its taking so much boost to get that power.
Old Jan 23, 2009 | 06:51 AM
EARLdaSQUIRREL's Avatar
official honda whore
did i read it correctly? you were running 28psi on pump gas?
if so thats the reason right there
Old Jan 23, 2009 | 08:03 AM
sleepencivic's Avatar
yea get a new turbo even just a new t3/t4 57 trim .63 a/r will get you where you want to be...i run one on my stock b16a at 11psi i made 320 at the wheels tuned by matt shue
Old Jan 23, 2009 | 03:07 PM
stalyun's Avatar
this is a legit question.
i thought it depended on how much power the engine made that decided weather or not i needed race gas. there is another guy that had same motor built. almost exact spec's except on a 60trim yielded 432whp on pump gas.
20 psi on a 50 trim is different that 20 psi on a 60 trim. so why would it matter if i ran 28psi on my turbo if it got me to the same HP goal?
just wondering where cfm comes in
Old Jan 23, 2009 | 03:35 PM
Silva Bullit DC4's Avatar
Two words...turbo efficiency.
420 is a little much to be asking of a 50 trim, power AND pressure wise.
Old Jan 23, 2009 | 04:10 PM
stockb18c's Avatar
^ agreed remember those words right there...turbo efficiency!!!
Old Jan 23, 2009 | 10:53 PM
blinx9900's Avatar
As stated, in a nut shell, your turbo is too small.
Old Jan 24, 2009 | 04:08 AM
spectacle's Avatar
Small turbo+turbo out of its efficiency range = hot air into motor
hot air into motor = high combustion temps + lean fuel mixture
lean mix+high temp = boom
So yea, get a bigger turbo.
Old Jan 24, 2009 | 02:19 PM
stalyun's Avatar
i checked out turbonetics site, it says that this turbo is good to 325-425 HP. if i was getting close to that level i should just turn boost down so im operating out of the turbo efficiency. i need to check the compressor maps ...
Old Jan 24, 2009 | 02:51 PM
blinx9900's Avatar
Thats a big gap, the 425 is probably with a stage 5 turbine wheel and .82 turbine housing and still the compressor would be out of its efficiency range, as stated above you probably have a stage 2 turbine wheel and no its not worth it to upgrade just buy a bigger turbo.
Old Jan 24, 2009 | 02:53 PM
rip94delsol's Avatar
With sleeves why did you just go .020 over? why not go 82 or 83mm?
Old Jan 24, 2009 | 03:59 PM
stalyun's Avatar
because at first did not sleeve the block. bought pistons for 81.5mm (wasn't gonna sleeve) then the block went boom.
from what i can see on the compressor maps, im gonna need to turn down the boost for now, till im able to get a bigger turbo. this turbo for the stage 2 wheel is rated from 325-345. so thats where ill
stay at for now.
Old Jan 24, 2009 | 06:05 PM
SovXietday's Avatar
Also mind that horsepower ratings are flywheel, never wheel.
Terrato
Sep 30, 2010 02:44 PM
turboman2.2
Sep 5, 2010 06:18 PM
jody754
Jul 22, 2009 07:25 PM
NLR808
Apr 13, 2009 01:45 PM
NOKTURNALCARCLUB
Sep 10, 2007 10:51 PM
