Need input on turning up the boost
Old Sep 13, 2005 | 05:15 AM
bigdgsr's Avatar
Default Need input on turning up the boost
Current Mods:
00 GSR (90k, 5k with Turbo)
B18C1
SFP Manifold
SFP 2.5" DP
2.5" Test Pipe with 2.5" Exhaust
Garrett 60 Trim .63 AR Turbo
Tial 38MM Wastegate
JRC FMIC
2.5" IC Piping
HKS SSQ BOV
440cc Injectors
B&M FPR
AEM Fuel Rail
Walbro 255 lph Pump
Skunk2 IM
ITR TB
ITR Valves, Springs, Retainers
ITR Cams
Skunk2 Cam Gears
3-Angle Valve Job
ARP Head Studs
Cometic Turbo Headgasket (Compression is 9.5:1)
Nuformz Block Guard
OBDIIB to OBDI conversion
P28 ECU tuned with CromePro
Right now I have been tuned for 9 pounds. Car has been running perfect for 5k miles. I am going to be taking it off the street in about a month and half. My question is would it be OK to have it tuned for 11 pounds of boost right now. If I blow something, I'll be OK cause I am building the block over the winter. A good idea or no?
Thanks
Old Sep 13, 2005 | 06:05 AM
11seclude's Avatar
Default Re: Need input on turning up the boost (bigdgsr)
leave it where it is 2psi isn't ****!
Old Sep 13, 2005 | 06:27 AM
turbosi03's Avatar
Default Re: Need input on turning up the boost (11seclude)
hehe, already got te itch to turn up the boost... if your building it and summer is about over soon, I would just wait man... yeah most of us blow a motor before rebuilding it, but you really do take a chance of having a lot of extra cost if it blows in an ugly maner... like dropping a valve for instance, or putting a rod through the side of the block...
you'll most likely just blow the ring lands though...
I say be nice to the GSR, wait for the build
Old Sep 13, 2005 | 06:45 AM
drumking15's Avatar
Default Re: Need input on turning up the boost (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">hehe, already got te itch to turn up the boost... if your building it and summer is about over soon, I would just wait man... yeah most of us blow a motor before rebuilding it, but you really do take a chance of having a lot of extra cost if it blows in an ugly maner... like dropping a valve for instance, or putting a rod through the side of the block...
I say be nice to the GSR, wait for the build </TD></TR></TABLE>
couldnt agree more...2psi isnt gonna do anything...well it will...but you wont notice the difference....crank it to 15....then retune...and youll def notice a power gain! but then again your already close to maxin out those puny injectors...so i wouldnt push it to much farther
95eggsr66
Aug 4, 2012 06:42 PM
black_ek
Mar 9, 2007 10:04 AM
bigdgsr
Apr 18, 2006 01:29 AM
bigdgsr
Dec 13, 2005 09:09 AM
1bar_ek
May 25, 2005 08:44 AM
