Need help with XS MBC
Mine is silver.. But its weird cause when i do the three full turn i start to hear a leakin sound from the mbc. But when i undo it its sealed up again.. Kind of weird.
One last question.. So as i turn it 3 full turn counter clockwise.. after that one knot up is equal to 1 psi? It doesnt really say from the intallation paper..
when you hear the bleeding sound your idle might jump up. mine did. so im assuming you have it hooked up from your vacuum source. i then switched and hooked it up straight to the turbo housing nipple, which wont bleed air at idle. im no professional though
Hmmm.......is that leaking noise really loud?!?! Like you can hear it clearly at WOT coming from your engine bay?!?!
I have a Dual MBC from XS and i'm having some leaking issues as well. Only mine is seems to be leaking all the boost out or something.
yeah u can hear it.. Turned it three full turn, went up 3 knots.. tested on the road, I can feel it pull a lot harder than before.. So i guess its not leakin boost cause it pulled really hard..
From 7 psi I went up to 10..
The only thing i have a problem is when i redline that ****, my wheel start to left n right.. It was little bit hard to controll it.. Didnt have this problem on 7 psi...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4turbo408 »</TD></TR><TR><TD CLASS="quote">yeah u can hear it.. Turned it three full turn, went up 3 knots.. tested on the road, I can feel it pull a lot harder than before.. So i guess its not leakin boost cause it pulled really hard..
lol got torque-steer
</TD></TR></TABLE>lol got torque-steer
The instructions say each full turn ('fine' adjustment screw, top of blue cylinder) is 1-2 psi - assuming you set it at the base psi of your wastegate first. Basicly on any of their mbc's you increase boost with a counter-clockwise adjustment of any screw.
If you get the high-perf mbc/dual mbc you also have a course adjustment, which is a regular ball/spring. The two black o-rings on the top of the cylinders are in fact bleeder holes, which is how you fine-tune it.
Hondabwoizmari
Jan 11, 2019 06:06 PM
tallblondkid
Dec 20, 2007 04:52 AM
