!!Need help with turbo oil return line!!
Re: !!Need help with turbo oil return line!! (ki11a8ee)
a 45 degree would be a good idea and put it as high as possible, where your pointing the hose right now isnt going to cut it.
I would get one of these for the bottom of the turbo http://cgi.ebay.com/ebaymotors...ZWDVW it will gain you some hight on the pan
well i was thinking of taking off the straight fitting thats on the turbo drain flange and putting a 45 degree fitting on the flange instead.
It looks like you can just put a 90* fitting on there, weld a -10 weld-fitting on the pan and use about 2 inches of line to connect it all.
MADEINIRAQ
06-19-2007 10:55 PM
