Need Help Quick Tonight!!!!!!!!!!!!!!!!!!
Old Nov 22, 2003 | 08:14 PM
revhigh96's Avatar
Default Need Help Quick Tonight!!!!!!!!!!!!!!!!!!
I have a 96 Civic EX with B18c5 turbo installed.
My question is I just installed new injectors and now my fuel pump and SAFC-II dont seem to be getting any power!!!!! I need to solve this problem tonight! Everything else seems to be fine, fuses and I also jumped the CEL code wire and no codes! When I turn the key everything seems to be fine just I dont hear my fuel pump and the SAFC-II will not turn on!
Thanks in advance, Mike
Old Nov 22, 2003 | 08:28 PM
revhigh96's Avatar
Default Re: Need Help Quick Tonight!!!!!!!!!!!!!!!!!! (revhigh96)
please help me I need my car working ASAP!!!!!!!!!!!
Old Nov 22, 2003 | 08:31 PM
b16ahybrid's Avatar
did you remove any fuses before the injector install?
Does the car start?
retrace your steps in the injector install.....installing new injectors shouldn't have anything to do with your fuel pump or safc
Old Nov 22, 2003 | 08:46 PM
revhigh96's Avatar
All I did was disconnect my battery! someone mentioned that it might be the main relay, would that make sense???
Old Nov 22, 2003 | 08:53 PM
espanol's Avatar
Default Re: (revhigh96)
if you don't hear the pump come on and the car won't start it could be your main relay, however i've never seen a main relay go bad in your year model.usually main relays go bad in 88-91.your best bet is to retrace your steps, check all the fuses under the hood.
Old Nov 22, 2003 | 08:59 PM
2K_TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhigh96 &raquo;</TD></TR><TR><TD CLASS="quote">All I did was disconnect my battery! someone mentioned that it might be the main relay, would that make sense???</TD></TR></TABLE>
Did you reconnect your battery?
Get a multimeter and check all your fuses.
Kyle
Old Nov 22, 2003 | 10:10 PM
revhigh96's Avatar
ok everything is fine now When we tightened the fuel rail down it pinched one of the injector wires creating a short to the ground Thanks
always40
Dec 16, 2010 10:10 AM
JasonHi
12
Jul 12, 2010 12:14 AM
Lsweez
Jun 28, 2007 10:08 PM
posterchild
Apr 30, 2004 04:29 PM
revhigh96
Nov 22, 2003 10:11 PM
