need help quick:
Old Aug 18, 2002 | 12:40 AM
uNF$@#!'s Avatar
Default need help quick:
in relation to the spring rate in a wastegate,
can someone point out to me the conversion between lb and psi?
for instance if someone tells me they have a 8lb spring in their wastegate, how much psi does that equate?
Old Aug 18, 2002 | 12:47 AM
sutrusu's Avatar
Default Re: need help quick: (Soup ****)
pound = pound
psi means pounds per square inch
8 pounds = 8 psi
Old Aug 18, 2002 | 12:48 AM
quickspoolin's Avatar
I think they're the same psi =pounds per squared inch.
Old Aug 18, 2002 | 01:11 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: need help quick: (quickspoolin)
You mean to tell me 1=1?
Old Aug 18, 2002 | 01:18 AM
turbocoupe's Avatar
Default Re: need help quick: (Arturbo)
So if you have an 8lbs spring. How much boost should you be able to run? Correct me if I am wrong but the Greddy comes with an 8lbs spring in the wastegate correct?
Old Aug 18, 2002 | 01:26 AM
uNF$@#!'s Avatar
on me.
running 7 psi on a 8 psi spring sounds impossible now....
pcguy760
Jul 8, 2011 09:08 AM
D15Bbigred
Mar 11, 2007 10:05 PM
.RTErnie
Jul 7, 2005 08:31 PM
NORCALCVC
Feb 15, 2005 11:57 PM
Nextelbuddy
Mar 28, 2004 08:43 PM
