Need help pulling engine codes
Old Dec 2, 2007 | 11:30 AM
b16bri's Avatar
Default Need help pulling engine codes
I have a 99 civic SI oblvousbly obd2 but i have a 92-95 jdm b16a obd1 motor in the car along with a p30 ecu with crome i have the jumper between harness and ecu to make that swap work. My question is my car is in limp mode and it wont let me rev past 3500 rpms and i have a check engine light on. I tryed putting a paper clip in the service plug near the ecu kick panel and than I put the car in the on position ( not starting up just on ) the CEL light just stays lit it dosent flash or anything ? dose anyone know why this is ? considering it's and obd2 car can i use a scanner to check them or will it not work due to haveing a obd1 ecu ? i need help about to get the car tuned i just need to fix this problem and i can get the computer to throw any codes ? I know my knock sesnor isn't hooked up but i dont think this would cause limp mode how do i pull the codes and why isn't the service plug working ?
Old Dec 2, 2007 | 11:42 AM
coneheadsracing's Avatar
Default Re: Need help pulling engine codes (b16bri)
Is the ecu chipped, with a removeable, ie tunable chip. Or is this getting done when you tune it. A solid light means bad ecu. Which, if it is chipped, can mean bad chip, no tune/basemap on the chip and so on.
Old Dec 2, 2007 | 11:52 AM
b16bri's Avatar
Default Re: Need help pulling engine codes (coneheadsracing)
it's a freshly built motor not tune maybe 10 miles on the motor the ecu is chipped with crome I want to get it tuned very soon I had my car at a shop and i pulled it out of there b/c i got ripped off bad from them theres no tune and i dont know if there is even a basemap. So how do i correct this just bring the car to get tuned and if it's b/c of no tune or base map my new tuner will take car of that for me. Or do i go somewere and get a base map set up i dont know what to do.. There also is a vfac that i havent removed yet if that matters ?
Old Dec 2, 2007 | 12:00 PM
b16bri's Avatar
stupid questions but how do i know if theres a basemap on the chip ? i dont think there is but i dont know i'm new to turbo hondas and as far motors and set ups and stuff i know a good amount about but as far as a ecu and wireing i'm kinda learning as i go
Old Dec 2, 2007 | 01:15 PM
b16bri's Avatar
i guess my questions is can i get it tuned and fix the problems or do i need to fix the problem first before tune. I'm not sure what direction to turn to
Old Dec 2, 2007 | 05:04 PM
Not really something you can figure out on the internet. How close is the place your going to get a tune at? I'd take the computer to them and have them check it out for you. There may not even be a chip in there. You can't check for a map unless you have a chip burner/reader. So your likely out of luck there.
Old Dec 2, 2007 | 06:01 PM
b16bri's Avatar
well i have 2 p30 ecu one thats not chipped just lieing around and one that is chipped which is in the car and i opend up both covers and i can see the chip in the ecu so i'm 99 percent postive the chips is in there. There are a couple dyno shops around my area (CT) but none that really specialse in hondas that i know of . I planed on brining my car to new york to get tuned so the place is about an hour and a half away althos like i said there are some shops that do hondas 15 - 30 minuts away. So you think a ride to New york or a local shop is my best bet ? IF so what do i ask when i get there to check if theres a map and if not than get one or just get it dynoed / tuned ?
Old Dec 2, 2007 | 06:05 PM
CoreyR's Avatar
if its got a solid cel even when you jump the service connector that means it has a bad burn on the chip and thats why its in limp mode. im in CT and if youre willing to drive up to plainville/southington arean i can burn you a new chip.
although your best bet would be to put the stock unchipped P30 in and a set of stock injectors so you cn drive the car normally.
Old Dec 2, 2007 | 06:53 PM
Default Re: Need help pulling engine codes (CoreyR)
If you go to one of the shops, bring the ecu, or at least the chip, tell them what your setup is and see if they can get you a basemap on it. If you still have the stock injectors in, then like coreyR said, use that computer and see if it's better. Assuming it is, stay out of boost, and get it tuned. If you get a basemap, and don't have a wideband in the car, stay out of boost also, and get it tuned
Old Dec 2, 2007 | 07:42 PM
b16bri's Avatar
I have a wideband and i have a stock set of older prelude injectors 310 insted of 240 so they work run a little richer but work to drive the car and corey R do you have a shop up there ? if so i'll drive / bring the ecu there do you have a shop if so whats the address / phone number
Old Dec 2, 2007 | 07:44 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16bri &raquo;</TD></TR><TR><TD CLASS="quote">I have a wideband and i have a stock set of older prelude injectors 310 insted of 240 so they work run a little richer but work to drive the car and corey R do you have a shop up there ? if so i'll drive / bring the ecu there do you have a shop if so whats the address / phone number </TD></TR></TABLE>
i have a shop but its not a business just a personal shop. if you want to bring the car up this weekend i can try to help you out.
Old Dec 2, 2007 | 07:45 PM
b16bri's Avatar
ok do you have an address / phone number i can reach you at
Old Dec 2, 2007 | 07:48 PM
CoreyR's Avatar
pmed you my number
Old Dec 2, 2007 | 07:51 PM
b16bri's Avatar
insted of brining the car down can i bring just the ecu
Old Dec 2, 2007 | 07:54 PM
CoreyR's Avatar
yeah thats fine.
Old Dec 2, 2007 | 07:56 PM
b16bri's Avatar
stupid question but how do you get the personell messages section i'm quessing thats what PM stands for lol
Old Dec 2, 2007 | 08:06 PM
CoreyR's Avatar
click on my profile in the top right corner of the screen and then click on instant message history
Old Dec 2, 2007 | 08:13 PM
b16bri's Avatar
thanks man i appreacuate all the help and ya that would be great if you could help me out i've been working on this car for about to years and am just about to get the car tuned once this idle mode problem is taken car of and hopfully it shouldent be very hard to be honest i bet all i need is a base map i bet you that shop never gave me one ? how much dol you charge and is this at your home or at a shop somewere
Old Dec 2, 2007 | 08:19 PM
CoreyR's Avatar
only thing ill charge is for the price of the chip with is about 5 bucks. basically just doing it to help you out cause im a nice guy
this will be at my shop.
Old Dec 2, 2007 | 08:36 PM
b16bri's Avatar
alright cool thanks man i'll call you one day this week and hopfully set something up like a time i can bring the ecu down and hopfully solve this problem
HuntsAlone
15
Aug 6, 2015 09:27 PM
sikvic00
20
Jul 9, 2011 01:49 PM
jonathan13
Aug 24, 2010 11:19 AM
CeeJayy
Jul 27, 2007 07:48 PM
phat_gsr98
Jul 13, 2004 05:40 AM
