Engine swap engine light help
So I bought a project car a while back.
It is a 99 civic si with a swapped B16A1.
With my obd2 ecu it would throw a crankshaft position sensor code and this engine doesn't have one. Just get a new ecu and it should fix it. Simple enough, right?
Well I bought an obd1 ecu that said it should fix this code.
However, the scanners won't read this ecu now and I still get a check engine light. I don't really know what to do. I just want to get this car registered.
Re: Engine swap engine light help
I just went to two shops, a sears auto center, and an oreilly's. One was an automatic scanner and the other you input it yourself and both didn't work. I used an ecu jumper conversion harness from obd2b to obd1.
EDIT: I was looking at some connectors near my ecu because I was doing some research. I saw the check connector wires next to my ecu and it only had one pin in there and there wasn't another one.
C1, C4
C11, C14. I'll attach pictures so you can confirm this or not.
EDIT: I think I am the stupidest man alive. I thought my vehicle was obd2a when it was obd2b when I bought an obd1 ecu I even bought the wrong conversion harness the first time. How did I not think of this before? OH MY GOODNESS. I am a dumb dumb.
IN CONCLUSION: You helped me realize something that I could have done all along and I am able to fix my car. You sir are a genius and I wish I could give you something. For now a hug will have to do
mastamind
02-18-2006 10:27 PM
