Looking for a weird dyno graph
Old Dec 2, 2007 | 02:34 PM
Dunc's Avatar
BCICAN
Default Looking for a weird dyno graph
Need:
Does anyone have an RPM vs. Time graph from their turboed motor? If possible I would like to see that graph from a car running lower boost and see what it looks like when the power curve is relatively linear. I'm curious to see just how linear you can get it when sizing a turbo to not spool like instantly.
Why:Generally you just see power vs. rpm. I'm having a discussion with someone and they seem to care more about the nonlinear curve of rpm vs. time rather than the power/torque curve.
Old Dec 2, 2007 | 05:17 PM
xenocron's Avatar
Default Re: Looking for a weird dyno graph (Dunc)
Depending on what dyno you use...time will always be the same as the dyno only lets the car accelerate at a set rate.
Old Dec 2, 2007 | 08:49 PM
tokesGTR's Avatar
Default Re: Looking for a weird dyno graph (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Depending on what dyno you use...time will always be the same as the dyno only lets the car accelerate at a set rate.
On eddy current dynos yes, but you'll blow through a dynojet as fast as your motor can spin it.
nexxxt
May 17, 2007 08:22 AM
1fstcorrado
Aug 9, 2005 12:09 PM
WhoDoYouThink
May 9, 2005 12:10 PM
D-tuned
Nov 11, 2004 07:28 PM
Project X
Jun 20, 2002 01:46 PM
