need help please!!!!!! turbonetics MF-2 how to connect with MSD digital 6?????
PLEASE HELP!!!
if u have a turbonetics turbo kit (f-max) then u know the turbo kit come with the 2 extra 440cc injectors with the kit that's controlled by the MF-2 little piggy back that control those 2 injectors. i now installed MSD digital 6 and the instruction only tell me how to install the MF-2 with the honda old distributor system with the 12 volt now since i upgrade the ignition system i dont know where to connect the wires. on the instruction all it says is (*** if u are using a ignition amplifier, do not connect the mf2 power signal to the coil + or - the mf2 uses 12v and the 200-400 volts from an amplifier will destroy the mf2. find a alternate RPM signal***) I FOUND OUT ON THE DIGITAL 6 THERE'S A RPM OUT PUT SIGNAL BUT I DONT KNWO HOW I AM GOING TO CONNECT THE + AND - COIL WIRE TO THAT. IF U ARE RUNNING A MF2 SYSTEM WITH THE MSD IGNITION PLEASE LET ME KNOW!!!!
THANK YOU
THANK YOU
