Need help to pick a turbo
Old Mar 14, 2008 | 08:15 PM
ral24_hct's Avatar
Default Need help to pick a turbo
ok this is my problem a have a b20 vtec turbo with obx topmunt manifold and I am using a t70 turbo .70/.84 a did 424 whp ay the dyno at 17 psi i am looking to make 450 whp on pump gas but with this turbo the lag too big I need a turbo to reduce a lag but that let me go up to 450 whp on pump gas and 550whp with racing gas what turbo do you recomend
Old Mar 14, 2008 | 08:28 PM
blinx9900's Avatar
Default Re: Need help to pick a turbo (ral24_hct)
budget?
Old Mar 14, 2008 | 09:03 PM
ral24_hct's Avatar
$600 or less
Old Mar 15, 2008 | 10:48 AM
Schister66's Avatar
Man U FTW
Maybe a used T3/T67HO or something along those lines. Once you start making more power, it takes more money to play the game. Also, is your B20 a stock sleeve setup?? If so, i'm impressed that its lasted that long....
Old Mar 17, 2008 | 07:37 AM
hatchkid91's Avatar
i say get a use t3/t4 turbo or one from a dsm
Old Mar 17, 2008 | 08:21 AM
4g63powered's Avatar
Default Re: (twinturbosupra123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbosupra123 &raquo;</TD></TR><TR><TD CLASS="quote">i say get a use t3/t4 turbo or one from a dsm</TD></TR></TABLE>
No stock DSM turbo will put up those numbers. Check to see if Forced Performance makes any turbos specifically for Hondas, they make good stuff
EJ8Squad919
Jun 6, 2012 07:31 PM
DAslammed
Nov 12, 2007 05:42 AM
mrx
Oct 15, 2005 08:32 PM
lakyoumo
May 26, 2005 07:33 PM
