Need help with installing turbo timer w/ alarm
Old May 12, 2003 | 05:19 PM
Civic Type-R's Avatar
Default Need help with installing turbo timer w/ alarm
Hi guys, I'm trying to install my new Apexi turbo timer, but I have no idea where the blue and green wire goes. I did a search and found something about relaying on of those wire with the alarm, but the seach result is not very clear. Can anyone explain where the blue and green wire goes.
thanks
Old May 13, 2003 | 01:04 AM
civicshowracing65's Avatar
Default Re: Need help with installing turbo timer w/ alarm (Civic Type-R)
i think that's the accessory wire
Old May 13, 2003 | 05:14 AM
turbotypeR@SPEC's Avatar
25 Year Member
the green goes to primary ignition(blackw/yellow in steering column) and the blue to secondary ignition(solid yellow).hook the ignition wire of the alarm to accesory(white w/black).
Modified by turbotypeR at 9:19 AM 5/13/2003
Old May 13, 2003 | 11:51 AM
Default Re: Need help with installing turbo timer w/ alarm (turbotypeR)
still not very clear about the blue wire. Does it go to the solid yellow or white w/ black...??
thanks
Old May 13, 2003 | 11:58 AM
2000GSRT's Avatar
I would like to know how to wire up a turbo timer if you have a factory alarm also. I've done a lot of searching, but nobody has come up with a definate answer that I have read.
I know it involves a relay though
Old May 13, 2003 | 05:35 PM
25 Year Member
the blue wire goes to the large solid yellow coming from the ignition switch.the white/black goes to the ignition wire of the alarm.you do not need a relay unless you want to disable the shock sensor.as far as doing this on the factory alarm,if you find the ignition wire that powers the factory alarm you can cut it and hook the alarm side of the wire to the white/black wire.
Old May 13, 2003 | 07:36 PM
Ok, forgive me for being slow on this, I got this far:
Green wire goes to the primary ignition (black w/ yellow)
Blue wire goes to the secondary ignition (solid yellow)
Now, where is the white w/ black wire coming from? from the ignition as well??
And that goes to the ignition wire of the alarm, correct? Do I cut it off and route it to the alarm ignition??
Thanks for the help, much appreciated.
Old May 14, 2003 | 06:40 AM
25 Year Member
all of teh wires come from teh ignition switch.you will know them when you see them.they are all large wires.you just cut the alarm ignition wire and route it to the white/black
Old May 14, 2003 | 08:24 AM
Got it, going to install now, see how it goes.
thanks
Old May 14, 2003 | 08:39 AM
extrmeboost's Avatar
so how do i find out which alarm wire is for the ignition
Old May 14, 2003 | 09:50 AM
Default Re: Need help with installing turbo timer w/ alarm (extrmeboost)
Ok, here is how far I got, the car doesn't turn off if I turn the key once, but if I turn the key competely off, then the car goes off too. What's the problem?
There is a wire link from the alarm brain to the primary ignition (black w/ yellow), so I assume that is the alarm ignition wire, therefore I cut that out, and link that to the white/black wire, correct??
Please help.
Old May 14, 2003 | 03:07 PM
25 Year Member
i don't know man, i assume you have the red hooked to constant power and the black to ground?the way you described the alarm wiring is correct.
if you know where the brain to the factory alrm is,you could possibly check for ignition at the brain.as long as there is only one that should be the wire you need.if you do not feel comfortable with doing it,just take it to a good stereo shop and see if they will do it for you.
BrothaSit
Audio / Security / Video
Mar 2, 2012 11:13 AM
dacohns7267
Mar 28, 2011 09:40 AM
k9n
Dec 23, 2005 04:04 PM
TypeRod
22
Sep 17, 2005 08:40 AM
Lei Siew Long
Jun 30, 2001 12:17 AM
