need help with installing greddy profec B....
Old Apr 28, 2006 | 01:18 PM
SPOON_BeIgHtEeNsEe's Avatar
Default need help with installing greddy profec B....
did u guys tap into the charge pipe for the IN... if so how did u do it? u think if i just drill the charge pipe, screw the fitting in and use some JB weld it would work? it says to tap the charge pipe on the greddy site but i dont know how to seal it up besides an O ring or JB weld...
or is there another way without tapping the charge pipe?
Old Apr 28, 2006 | 06:50 PM
Wideopentuning's Avatar
Default Re: need help with installing greddy profec B.... (SPOON_BeIgHtEeNsEe)
You can use the boost signal port on the compressor outlet if you compressor housing has one. If not its cake to drill and tap one 1/8 npt for the fitting of your choice. You can take that signal from any line that will have boost.
Old Apr 28, 2006 | 07:56 PM
dpetro1's Avatar
my profec b2 is just hooked up to my vacuum manifold. like the other guy said any vacuum source will work.
Old Apr 28, 2006 | 08:04 PM
96 GSR-T's Avatar
Default Re: need help with installing greddy profec B.... (dpetro1)
I had my Profec B drawing from my old Skunk2 Manifold, now I got a Victor X and it is also tapped off the ports on the back of it.
Old Apr 28, 2006 | 10:55 PM
turbosi03's Avatar
Default Re: need help with installing greddy profec B.... (96 GSR-T)
I used the port on turbo compressor housing... best source for +boost pressure to control the wastegate diaphram
Old Apr 29, 2006 | 04:01 AM
96 GSR-T's Avatar
Default Re: need help with installing greddy profec B.... (turbosi03)
yea my new turbontics 60-1 has that port.... will probably use it when I get up off my *** and do something
thegatekeeper14
May 20, 2010 08:20 PM
s4yama
Nov 6, 2008 12:01 AM
slowater427
Oct 2, 2005 06:44 PM
FredoSP
May 15, 2003 12:59 PM
91CivicSi
Sep 24, 2002 07:31 AM
