need help with injectors
Old Sep 20, 2003 | 06:52 PM
integra95's Avatar
Default need help with injectors
here is my story right now. I have a turbo with the wastegate set at 9 psi. i want to get something like a 680. Now if the injectors are to big will my ecu see that and turn them down. I don't have enough money for the aem ems yet. I would also like to turn the boost up when i get the aem ems thats why i wanted to get a 680 injector right now so i wont have to later on when the boost is turn up. Does anyone know where to get a different tial spring for the wastegate so maybe i can just run the stock injector until i get the ems.
Old Sep 20, 2003 | 06:59 PM
vtec.dc2's Avatar
Default Re: need help with injectors (integra95)
what kind of whp do you want to run? some people make 200whp at 10psi.. so... what whp, what rpm range.. what motor?
Old Sep 21, 2003 | 09:52 AM
integra95's Avatar
I would like to make about 350 to 400whp. I would be running about 20 psi nax, this will be on a ls motor, yes it is built.
Old Sep 21, 2003 | 01:41 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to make about 350 to 400whp. I would be running about 20 psi nax, this will be on a ls motor, yes it is built.</TD></TR></TABLE>
somewhere along 720cc should work, since you won't rev too high.. maybe you can do away with 550cc.. someone should give more detail answer on this.. till then 720cc
flangemastermike
Jul 1, 2008 11:06 AM
ryanmcdermit
Jun 9, 2007 08:41 PM
h22_crx
May 6, 2006 06:56 PM
SnOOpY-NO
Jan 13, 2005 10:49 AM
jdm.ej
Jun 23, 2004 11:10 PM
