need help with injector size and what program to use on my turbo setup
Sup guys I got a b18b1 block with gsr internals and gsr head b18c1
This is my setup
Ls block bore .20
Oem b18c1 crank
Eagle rods
Npr pistons for turbo 9.0.1 comp
Web cams for turbo
Unkown turbo valves
Supertech retainers and springs
450 dsm injectors 255 wlb pump
Gt30r gsp turbo at 13 psi
My questin is I'm trying to make 400 to 450hp what kind of injectros to use
Is crome a reliable chip for it since I'm low budget all ready and can't afforde a hondata s300
And sould I get a block guard
I'm all ears thanks
This is my setup
Ls block bore .20
Oem b18c1 crank
Eagle rods
Web cams for turbo
Unkown turbo valves
I'm all ears thanks
Consider these guys http://www.cylindersupportsystem.com
For that power level you'll want at least 750cc injectors for gasoline.
Crome is fine.
Thats an eBay turbo?
Crome is fine.
The css system isn't necessary for 450whp at all, and can be achieved on stock sleeves, provided he has the correct tuning equipment, and tuner.
Unfortunately, the DSM 450cc injectors will not support that horsepower level, not by a longshot.
The best bet for the OP would be to use the EV14 Bosch-style injectors .. the OP can take his pick between Injector Dynamics, FIC, Grams, etc..
For 450whp, best decision is to choose between 725cc and 1000cc size depending upon the type of fuel he/she plans to use. Unfortunately, CROME isn't the best at supporting these larger injectors to give stock characteristics, so once again, he/she is limiting himself right from the start.
If the OP can't afford a good management system, that means he/she can't afford a competent tuner, (because few, if any competent tuners even deal with CROME anymore) which means that he'll/she'll need to wait before trying to get 450whp..
As for a GT30 -- only the OP can tell us which manufacturer made it. But I suspect also its a Godspeed copy, which means its not a GT30R.
So, the OP needs to step their game up a bit more, get some better equipment and come back to us..
find a neptune dealer. a license is like 125. all the options you need. get some 1000cc injectors so you have room to grow. find a good reputable tuner
I got my car tuned 20+ times at do it DYNO. But since he moved.
He makes you sign like 10 pages of paperwork and doesn't let u touch your car
So if a coupler comes off they will charge you to bolt it up. Lmao
Ooo and u gotta buy plugs there. And pay them to install as well..
I'm completely satisfied with the tune I got at churches automotive
Sean is an awesome guy and is totally down to earth
But it's your choice.
I speak from experience.
If your scared. Go to church. Lol
To make 450 whp on pump or race gas, our 900cc high impedance injector would be a good fit: http://fuelinjectorclinic.com/d-b-h/IS115-0900H
If you're using E85 you'll want to choose a larger injector like our 1100cc instead which should get you somewhere in that 425-450 whp range: http://fuelinjectorclinic.com/d-b-h/IS115-1100H
These injectors feature our Data Match Technology, the most complete flow matching and latency value information available in the industry. You can read more about it here: http://fuelinjectorclinic.com/data-match-technology
Good luck with your setup and if you have any questions we can try to help you here or you can give us a call at (561) 427-0082.
.adam.
Jan 28, 2006 12:05 PM
turboex
Apr 3, 2003 06:39 PM
