need help indentifying a turbo
Old Jun 9, 2010 | 09:50 PM
black da9's Avatar
Default what do you think of this turbo
Not sure what the model the turbo is, I know it's a borg warner with ett that's it.
Specs on the turbo are as follows.
compressor
inducer- 53 exducer-77 trim 47
3 inch inlet and 2 1/4 outlet
turbine
inducer-57 exducer-69 trim 68 A/R is 83
t3 divided inlet flang 3inch 4bolt outlet flang
I have these part numbers
Compressor Housing
53271013082
Turbine housing front side
1270 101 9061A
Turbine housing back side
BWS-GJS
XSIMO4.1
Wastegate actuator flange area on turbine
300507
1-D1
The engine is b18c1 9.1.1 pistons with eagle rods all arp bolts mild port and polished and valve angle job on head with gsr cams and type r valves, springs and retainers. 2 1/2 charge piping 3 inch exhuast.
Any help would be appreciated.
Last edited by black da9; Jun 12, 2010 at 07:37 AM. Reason: forgot to add something
Old Jun 12, 2010 | 07:38 AM
black da9's Avatar
Default Re: need help indentifying a turbo
bump
TwoKSiR
Jan 31, 2010 08:48 PM
eglslsd
Jun 14, 2007 05:36 PM
marko_think
Jun 28, 2005 02:55 PM
booscivic
Dec 15, 2003 07:14 PM
nitroedhx
Feb 12, 2003 08:55 PM
