Need Help I'm kinda Confused
Old Oct 31, 2004 | 06:24 PM
smoke3's Avatar
Default Need Help I'm kinda Confused
I have a b18b about 122000 miles alot highway.
I wanna turbo my motor but i have few questions i searched but i havent been able to get a direct answer.
This is my planned setup.
b18b
weisco pistons
eagle rods
oem headgasket
new oem bearings etc.
so basically by doing all this ill be dropping a few miles off the motor hopefully. it wont be competely stock any more
for the turbo i plan to run
t3/to4 ar.48 50 trim or something really close
blox manifold
tial wastegate
blow 3" with ac downpipe
tial 38mm wastegate
thinking about some mild headwork and jg or skunk 2 manifold
gonna get it tuneed with uberdata
ok my question is how much psi can i safely run on the motor on pump gas and what kinda number can i expect. I just want a estimate of what numbers i can run with this setup. My goal is 300 i dont really want more than that.
thanks
Old Oct 31, 2004 | 07:52 PM
Drew Peacock's Avatar
Default Re: Need Help I'm kinda Confused (smoke3)
Wouldn't bother with the head work or inletmani you should be able reach your goal on pump gas if not a blending alittle race gas in would see done it easily.
Old Oct 31, 2004 | 08:18 PM
m R g S r's Avatar
With that turbo, you could probally run as much boost as you want, meaning you can max it out. I'm guessing it's good for around 350whp.
namewasdallas
Apr 7, 2010 08:27 AM
g0tgot
Dec 19, 2008 11:15 AM
jdmrenzo
Jul 7, 2007 06:52 PM
Quickgti1.8t
May 13, 2006 10:28 AM
2LiterTurboSeR
Aug 26, 2005 05:11 PM
