need help ,i need info on these turbos SC61 and SC63 or something comparable
i need to knw w/c one to get,or w/c one is worth the money, need to decide on this, all guys who use this ,opinions will be appreciated,
i need something that will make me king of the streets
Re: need help ,i need info on these turbos SC61 and SC63 or something comparable (jdm_kenji)
Do a search, tons of topics on the sc61 and sc61. Then when you're ready to buy one, talk to arturbo
Re: (jdm_kenji)
SC61 goes for $775 retail, the SC63 before was posted as $1100 but recently Rod from Precicion said this and quoted "Sound,
The SC63 (which is a big shaft turbo) retails for $960 with the T04E cover. We rate that at just 10 to 20-hp above the SC61 76 trim, which sells for $185 less in the same configuration." So there is only a $185 difference but says it's only a 20hp difference in their ratings. Others have made GREAT #s with the SC63 but also the SC61 is awesome too, talk to At for your Precision Turbo needs I have posted specs on each of the turboes before too, so do a search and you should find them too.
