Need help with Greddy turbo kit on OBD1 Integra
There is a Greddy turbo kit on my friends 95 Acura Integra....he has a fmu, missing link, walbro 255 intank fuel pump, stock injectors, stock rail and stock regulator. The car runs and idles fine, but Whenever the throttle is 100% or it boosts, it goes no where, putts, backfires and runs really bad.
It is an OBD1 stock compression GSR. We didnt hook up the blue box either.
So I was wonding if anyone has had this problem and found a solution ....Need help asap!!!
BMW Güdentyte
Re: Need help with Greddy turbo kit on OBD1 Integra (2001civic10.02)
What ever happened to the 310cc injectors that the kit came with? The blue box won't work on an OBD1 integra btw and also, did you hook the FMU correctly? Some people installs them backwards. A DRAG owner might be able to elaborate that FMU setup for you since I'm still using the blue box.
Re: Need help with Greddy turbo kit on OBD1 Integra (CovertFI)
so if the side is in, that is the one that comes from the fuel rail to the fmu and the bottom is out to the tank right?
ohh and the rcs...the guy I bought it from skimped on me with them...and still charged me $3000
[Modified by 2001civic10.02, 11:46 PM 6/13/2002]
