need help on fuel for 240sx
Old Aug 12, 2003 | 07:08 PM
S14BEER's Avatar
Default need help on fuel for 240sx
been researching and putting together a junk-yard turbo set up for my 1996 240SX for a while now, and im stuck at fuel management....
ive been to all the 240SX forums and there isnt too much info for turbo-ing the KA24DE motor. Plus, i heard honda-tech was the number one forum for turbo-set ups, so i wanted to find out for myself..
this is what i have in mind for my car:
z31 T3 turbo (under $200)
1g eclipse BOV (not sure - cheap)
Log Manifold from JGS($250)
downpipe (get it done custom at a muffler shop, mandrel bent 3" out of mild steel - not sure - $125?)
manual boost controller ($40)
saab 9000 FMIC
I wanna run about 10 psi...but for that i need the right fuel management system..
i was thinking about getting sr20det injectors (hoping to spend under 150 for them)
and then run a hacked MAF ( i know i can get a KA24DE maf on ebay for like 10 bucks)
only thing is that im not quite sure about the hacked maf...is there anything better?? what do you guys think??
Old Aug 12, 2003 | 07:15 PM
AlphaKennyWun's Avatar
Default Re: need help on fuel for 240sx (S14BEER)
I would at least start with a larger fuel pump say 255lph, larger injectors like 370cc (depending on how much power you want to make) and a 8:1 FMU. Your also going to need a map sensor controller, i have on for sale
Old Aug 12, 2003 | 07:17 PM
DA-MAX's Avatar
this forum is dedicated to KA24ETs and KA24DETs...
http://www.nissaninfiniticlub....d=131
Nico Forums are the ****!
Old Aug 12, 2003 | 07:18 PM
S14BEER's Avatar
Default Re: need help on fuel for 240sx (S03Burner)
i was hoping to put out 250 hp with the set-up, 240sx comes with 150hp and 160 torque...
i was actually thinking about running a 12:1 FMU....is that not right?
Old Aug 12, 2003 | 07:50 PM
bruthaboost's Avatar
I'm in a similar situation. What will probably be the easiest is to run an addition fuel injector controller for more fuel and a msd btm for timing. I'd also upgrade the fuel pump as previously mentioned. They're band-aids, but functional band-aids. I'd check out the e-manage, though from the support site:
http://autos.groups.yahoo.com/group/emanage/
their are still some issues that need to be worked out. Their is one person running the emanage on his ka24de.
edit: grammer. I can't spell
FormerDSMguy
Mar 17, 2017 06:47 AM
BG-Teg
Apr 12, 2007 07:14 PM
98civiccx
Nov 6, 2004 09:38 AM
jdmotorsports
Jul 3, 2001 05:54 PM
