represent your top mount + p/s setups...
Old Feb 12, 2006 | 04:40 PM
rorik's Avatar
Default represent your top mount + p/s setups...
I'm just trying to get some ideas on how to mount my holset hy35/he341 whatever it is turbo. I want to build a top mount because I believe that design has the highest power potential, but i want to keep my power steering. I'm looking for a little inspiration before I start test fitting things..
thanks for any pics...
Old Feb 13, 2006 | 07:37 AM
80884's Avatar
Default Re: represent your top mount + p/s setups... (rorik)
Depending on you setup, engine/car etc...I just moved the power steering down to where the a/c used to be. 00 civic B18a engine, I have to make a bracket for the lower power steering mount but the rest were factory mounts. This should give you an idea...
Old Feb 13, 2006 | 08:58 AM
mattcivic's Avatar
Default Re: represent your top mount + p/s setups... (80884)
not exactly what u are looking at but close.
this whole kit is for sale link is in my sig below.
Old Feb 13, 2006 | 09:01 AM
splitime's Avatar
Default Re: represent your top mount + p/s setups... (mattcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">this whole kit is for sale link is in my sig below. </TD></TR></TABLE>
Not with that link to edit the post it isn't
Old Feb 13, 2006 | 09:06 AM
mattcivic's Avatar
Default Re: represent your top mount + p/s setups... (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Not with that link to edit the post it isn't </TD></TR></TABLE>
thanx its fixed now
Old Feb 14, 2006 | 09:54 AM
rorik's Avatar
I used to a have a manifold similar to that hytech one before.. although my manifold's quality wasn't comparable to that..
What I'm looking to do is keep the p/s setup original, but I could relocate it, I guess..I've already altered almost every single thing in my engine bay, what's one more thing..ugh..
I was kinda thinking of having the holset compressor face toward the passenger side of the b18, clocked with the 90deg outlet on the bottom, going right to a big liquid intercooler. I don't like the way that makes the turbo sit so far out form the head though (since the exhaust housing isn't on center or whatever) ..if the compressor faced toward the driver's side, the mass of the turbo could be closer to the head, but that would cause me more problems..
by the way, the engine is a b18a1 with a gsr crank, eagle rods, endyn pistons, soon to be vtec with a gsr head in an 87 accord hatch. Sleeper status..
Old Feb 14, 2006 | 10:47 AM
weiRtech's Avatar
OG Fabricator
Default Re: (rorik)
here is mine i'm working on:
here is the space:
here is the manifold:
here it is installed:
with the turbo:
Old Feb 14, 2006 | 12:24 PM
b16hybridsol's Avatar
Default Re: (weiRtech)
where do you plan on fitting p/s on that at?
Old Feb 14, 2006 | 03:55 PM
mattcivic's Avatar
Default Re: (b16hybridsol)
buy my kit and u can have your PS still
Old Feb 14, 2006 | 05:45 PM
rorik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">where do you plan on fitting p/s on that at?</TD></TR></TABLE>
ha ha, no ****
Old Feb 14, 2006 | 05:52 PM
80884's Avatar
Default Re: (rorik)
Relocating it to where I did was simple. Simple for me anyway. Stock hoses, stock fluid resivoir, stock upper bracket (used to be lower bracket) make one bracket and get a belt.
Old Feb 14, 2006 | 06:32 PM
JustaZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">here is mine i'm working on:
here is the space:
Manifold looks great, but are you using that as a jig??? If not where do you plan on bracing it?? Looks like 16ga at best.... Just my $.02, not trying to bust you *****, but you may wanna think about building it to take some punishment.
Old Feb 14, 2006 | 09:00 PM
Tony the Tiger's Avatar
Haha, where's the room for power steering?
Old Feb 14, 2006 | 09:07 PM
k24em2's Avatar
Default Re: (JustaZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustaZC &raquo;</TD></TR><TR><TD CLASS="quote">Manifold looks great, but are you using that as a jig??? If not where do you plan on bracing it?? Looks like 16ga at best.... Just my $.02, not trying to bust you *****, but you may wanna think about building it to take some punishment. </TD></TR></TABLE>
Most high end manifolds use 16 gauge.
Old Feb 15, 2006 | 02:01 AM
JustaZC's Avatar
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Most high end manifolds use 16 gauge.</TD></TR></TABLE>
N/A manifolds use the 16ga. ...not usually the forced induction ones.
Old Feb 15, 2006 | 03:15 AM
wantboost's Avatar
Who is Mr Robot?
um, most high quality manifolds use 16g. go look at all the drag cars, etc.
this sch.40 plumbers **** is just a craze started for cheap turbo manis that weigh a ****-ton
Old Feb 15, 2006 | 04:16 AM
weiRtech's Avatar
OG Fabricator
yeah, sorry, after i posted it, i realized you wanted ps manis.... my bad.
as for using 16g, i will be welding in gussets on each runner and adding brackets to support it from the block. i've heard all the stories about cracking and i plan to take every precaution i can to try and support the turbo's weight.
Old Feb 15, 2006 | 04:34 AM
Turbo-charged's Avatar
Default Re: (mattcivic)
i dont think ive every seen anybody actually selling a hytech kit! most people who get them never let them go! somebody should jump on that
Old Feb 15, 2006 | 09:07 PM
rorik's Avatar
What wall thickness does for instance, full race, neukin, love fab, etc, etc, use? I thought they were all thicker than 16ga. How thick is sch 10? Isn't that a little thinner than sch 40? I don't have much experience with this, but I used sch 40 for a manifold I built about 3 years ago..
Old Feb 15, 2006 | 09:49 PM
PrecisionH23a's Avatar
Default Re: (rorik)
Pretty much everyone uses schedule 40.
Old Feb 16, 2006 | 07:14 AM
80884's Avatar
Default Re: (rorik)
2” x schedule 10 pipe 2.375" .065"
2” x schedule 40 pipe 2.375" .154"
2” OD x 16 gauge tube 2.00" .065"
I used schedule 10 on the manifold I made, It was 1.5" pipe size scedule 10 which was 1.6x" something I.D.
Old Feb 16, 2006 | 08:26 AM
weiRtech's Avatar
OG Fabricator
Default Re: (80884)
all 1.5" schedule 10 PIPE has a wall thickness of .109" all 16g TUBING is .065" wall thickness. schedule 40 is a little over kill at .145" wall thickness.
i believe most people are using schedule 10 304ss elbows.
Old Feb 16, 2006 | 10:42 AM
yee SERIOUS's Avatar
no hating
Old Feb 16, 2006 | 10:48 AM
weiRtech's Avatar
OG Fabricator
Default Re: (undercoverdc2)
hey it works, that is what matters basically. i'd like to see more pics from different angles. your design looks very simplistic and effective.
Old Feb 16, 2006 | 11:18 AM
c jackson's Avatar
threes
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">um, most high quality manifolds use 16g. go look at all the drag cars, etc.
this sch.40 plumbers **** is just a craze started for cheap turbo manis that weigh a ****-ton</TD></TR></TABLE>
no offence but maybe you should go look at some drag cars
