.::Need help with EGT Install::.
Old Jun 8, 2005 | 07:58 AM
kevino002's Avatar
Default .::Need help with EGT Install::.
where should I hook up these wires to in a hatch. I just need to know where everyone gets these sources at? any help is needed. Thanks.
RED - 12v Constant Source
Orange - 12v Ignition
White - Light Source
Old Jun 8, 2005 | 08:25 AM
kevino002's Avatar
Default Re: .::Need help with EGT Install::. (kevino002)
someone has to have some input?
Old Jun 8, 2005 | 08:36 AM
juka's Avatar
+12V from inside the fuse box... just probed around till I found a connector.
GND - i used the bolt on the firewall holding the fusebox bracket in place.
Not a hatch tho... an LS integra.
PROBLEM THO... my EGT gauge needle goes crazy depending on what accessories are on.. I mean it bounces around so much I could use it as a fan. Anyone know what would cause this?
(sorry for kinda hijacking your thread).
Old Jun 8, 2005 | 08:44 AM
kevino002's Avatar
Default Re: (juka)
so where is a good source for 12 Ignition (orange wire) its cool man its all about info.
Old Jun 8, 2005 | 09:59 AM
warrick's Avatar
Default Re: (kevino002)
your fuse box has ignition and battery connectors in it. they're the ones just chilling in the middle. probe, when you find one off, turn the key to on and probe again. if it's on, you've found your source.
and to the guy who posted with his hatch, check your grounds, and check to make sure your power source is still solidly connected.
Old Jun 8, 2005 | 10:04 AM
kevino002's Avatar
Default Re: (warrick)
thanks for the info, that is what I was going to do. man I love H-T.
Old Jun 9, 2005 | 08:33 AM
kevino002's Avatar
what the hell is a light source?? where do I conect the white wire??
Old Jun 9, 2005 | 08:53 AM
kevino002's Avatar
some one has to know, I need to hook this thing up before my dyno appointment today.!!
Old Jun 9, 2005 | 09:24 AM
mike1114's Avatar
light source = pull your light dimmer switch out and tap into the wire WITH constant power. I think it was red/blk on my hatch, I could be wrong, use a multimeter.
For other wires, use the five accesory male slots on top of the fuse box, again, use multimeter and tap into necessary ones. You can also tap light source from one of these.
Old Jun 9, 2005 | 10:25 AM
kevino002's Avatar
Default Re: .::Need help with EGT Install::. (mike1114)
thanks man, that is what I thought light source was.
Type-Spaz
24
May 29, 2017 07:13 AM
blk_eg4
Oct 11, 2007 11:04 PM
(760)doogie
Jul 9, 2007 04:20 PM
Nisif
13
Mar 6, 2006 07:38 PM
tyflip2
Nov 11, 2003 05:48 AM
