e-cutout question... NEED HELP
in the instructions to install an e-cutout, it says to wire the positive to a switched fuse which is only on when the ignition is on. why is this. would i be able to wire it to just the battery terminal? what would be the downside to this. need help quick. thanks alot
Re: e-cutout question... NEED HELP (tyflip2)
The switched fuse side is so the cutout only works when the key is on. Battery terminal it will have 12v+ all the time, what if the wire burns in two= dead short= your car is on fire. Now if you install a fuse less than 12 inches from the battery, no fire.
EFinawesomeman
12-31-2012 09:34 AM
ppfalcon
12-11-2005 01:14 PM
4doorH22
11-27-2001 09:48 AM
