need help. Donīt know which CP piston is the correct one for my application
1 Post
Hey guys...
Iīve got a B18C6 superdeck1 sleeved block by ERL performance a B18B crank and a set of B18B turbo tuff rods from manley. Now I want to go with some coated CP pistons. I want a compression ratio between 8.5-9:1. Iīm confused about which piston to take cause the compression ratio with a 9:1 CP piston on a B18C6 pottom end with C6 rods and crank wonīt be the same with my internals.
forbiddenera
Engine Machining & Assembly
09-07-2017 02:11 AM
wushubrian
25
08-31-2006 01:52 PM
