Need help with coolant flow question-
Old Dec 17, 2003 | 11:09 AM
_jester_'s Avatar
Default Need help with coolant flow question-
In this diagram (thanks WOTTEG) it shows the green line initially starting on the front of the head nearest the rad. and going to the IACV.
PROBLEM: My b16 head doesn't have that fitting for coolant. Actually when i put my skunk2 IM on, i ran the extra fitting on the skunk2, to my TB, which feeds the IACV. (may be wrong...only place i had to run it from though?)
**I guess my question is, what will feed the IACV once i do what's shown in the above diagram (not my picture), since i am using a b16 head?**
Old Dec 17, 2003 | 02:39 PM
_jester_'s Avatar
Default Re: Need help with coolant flow question- (XratedSi)
Ok, how about what should be feeding my TB with coolant? I am missing something...if i didn't have the skunk2 IM there is nowhere to feed the FITV, therefore its real hard to bypass- Anyone have a flow-chart of a obdII b16?
Old Dec 18, 2003 | 03:43 PM
_jester_'s Avatar
Ok, so i am thinking i am just going to block where the IACV feeds back into the hard pipe and call it done?
Vspronk
Mar 24, 2016 12:55 PM
dirtygerman
Apr 28, 2013 04:43 AM
D16SohcVtec
Apr 7, 2009 06:43 AM
B18 CYA
Sep 27, 2006 08:20 PM
ej0513
18
Jun 28, 2004 01:44 PM
