need help converting to the dark side
Old Mar 5, 2013 | 09:00 PM
Spawne32's Avatar
Default need help converting to the dark side
If you haven't read my thread, my non vtec b20 build has just been....well its a train wreck, a train wreck carrying nuclear waste and hazardous chemicals which is about to crash into a truck full of matches and dynomite.
I am considering going over to the dark side of the force, it is a painful process to accept but given the set back after set back with the non vtec setup, continuing down this path is pointless. Im going to run the b20 up to the beginning of the summer most likely while i build this replacement motor.
It's going to be LSvtec, my old b18b is chilling out in my garage just waiting for an opportunity to redeem itself, as it was the first motor that saw my supercharger kit. So im going to be having that sent out to CNCwerx for the CSS sleeve support system, like their design, and so far their results have been fantastic in my opinion, and i think it will make a great addition to run a small turbo on this as originally intended.
The big question now piston and rod choice, target horsepower goal is 300-350 at the wheels. Which would have been fine for RSmachine pistons like I had put in my B20, however once again im presented with the issue of, they dont work for floating pin's, IE: aftermarket rods.
Derek from DDTECH has already secured my camshaft situation since this needs to peak under 8000rpm because of the automatic trans. Which I can push out to 8200 if need be.
Now I know i need a ge LSvtec kit, but is there any other very important things i should know about this? I dont plan to run a girdle, but I do plan to run the ARP main studs and have the block line honed for it. I had considered stroker crank for 92mm but that seems like a stretch given how tight my budget is. Although it would help with my demand of lower peak RPM thats for sure...
Old Mar 5, 2013 | 10:38 PM
Builda'Teg_92's Avatar
Default Re: need help converting to the dark side
I thought the new version of RSmachine pistons accepted aftermarket rods?
Old Mar 5, 2013 | 10:41 PM
Spawne32's Avatar
I cant seem to find any sort of new version anywhere.
Old Mar 5, 2013 | 10:45 PM
I think pretty much everything you find now is the new version, I bought some 84mm's from Dopy888 on eBay 3 years ago and believe they were ok to use with aftermarket rods. Try looking up eagle rods and RS pistons. Seems to be a pretty popular combo.
Old Mar 5, 2013 | 10:49 PM
Spawne32's Avatar
Their 84mm pistons are floating pin i know that because i have them, but they specifically state that. Every 81-82mm rs machine, ycp, and nippon piston ive come across has been OEM press fit only, and getting a hold of RSMachines seems to be like pulling teeth.
Old Mar 5, 2013 | 10:52 PM
Nvm
Glad to See your still sticking with the auto trans though
Old Mar 5, 2013 | 10:58 PM
Spawne32's Avatar
Originally Posted by Builda'Teg_92
Nvm
i wont be swapping that out until it blows into a million pieces lol which will likely be never, because i have all the misplaced faith in the world in it. I do fear however my b20 may be cursed.
Old Mar 6, 2013 | 04:30 AM
DDTECH's Avatar
finally.. Fucken Vtec... yes.
Old Mar 6, 2013 | 05:50 AM
carlos8's Avatar
nippon racing made the b16 turbo pistons in 81 and 81.5 with floating pins,
i put a set in my friend car. The down side is they yield a very low compression. Loock for them on ebay as b16 pistons.
Old Mar 6, 2013 | 06:21 AM
Turbo-LS's Avatar
Id slap in a st of nippon turbo pistons and eagle rods if you arent planning on upping the power level in the future otherwise slap in eagles and CP's with upgraded wrist pins and call it a day. Good for 700hp and only limiting factor would be the rods.
Old Mar 6, 2013 | 01:56 PM
civickiller's Avatar
im confused
Old Mar 6, 2013 | 02:48 PM
Spawne32's Avatar
lol my YCP 84.5mm were press on, now im going 81.5 and i have the same problem. Although it does look like i can get the pistons i need, but odd ball compression choices.
Old Mar 6, 2013 | 05:08 PM
delsolintegra's Avatar
Did I read you're boosting a automatic?
What ECU can handle that?
Old Mar 6, 2013 | 06:44 PM
Spawne32's Avatar
P75 obd1 ecu combined with the separate TCU that comes with OBD1 automatic integra's. This leaves trans control functions separate from the tuning program which overrides the original factory programming. The TCU is then modified physically with the hard parts on the board to fool the programming and cause the trans to shift at whatever desired RPM is needed.
Old Mar 6, 2013 | 06:54 PM
SiRCiviC94's Avatar
Auto tragic!
Old Mar 6, 2013 | 06:55 PM
Spawne32's Avatar
Originally Posted by SiRCiviC94
Auto tragic!
this sounds vaguely familiar.
Old Mar 7, 2013 | 05:15 AM
Is your plan than to "chip" the P75 for boost i.e. Air fuel ratios, timing, manifold pressure? Develop a base map for it (avoid lean conditions). Tweak it with datalogging so there would be a smooth transition thru rpm's, manifold pressure changes so the transmission could have a chance to respond smoothly thru shifts?
Sounds challenging. Maybe add a transmission fluid coolant line that fluid will be working!
Old Mar 7, 2013 | 07:30 AM
Spawne32's Avatar
My ecu has been socketed with a moates demon running ectune for 2 years lol
Old Mar 7, 2013 | 08:57 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Wait, so what you are telling me this is what tuning is!?!?! This whole time I thought it was just BS on a screen.
OP - Main studs are completely unnecessary. If you use stock rods, go with upgraded rod bolts to account for higher RPM. Stroking is a waste of money in my opinion. Pick a better turbo charger to accommodate your specific build. At 350whp you will be pushing any cast pistons. Obviously detonation will have to be watched with an EXTREMELY watchful eye/ears.
Old Mar 7, 2013 | 09:02 AM
Spawne32's Avatar
*cough* check the username *cough*
ryanhauk
57
Jun 24, 2009 07:42 AM
89HatchSI
Oct 9, 2005 04:38 PM
TootiteIntegra
Sep 15, 2003 11:18 PM
