Need Help with Compression Ratio !!!
I'm running a B18c Bored Block to 84.5mm Open Deck with a Precision GT-35R with the High Output housing.... I have yet to deside on on a low compression Piston dont know How low I should Go. If Either a 9:1 or maybe 8:1 ...... I want to Hit around 600whp...... Need Help Deciding which Compression Ratio I should go after......?
What variant of the 35R is going to make 600wheel at 20psi?
if you want it to last the lower the compression the better. 8-9 to 1 for pump gas... i include e85 in that simply because you never know the exact octane you are going to get. e85 is good for a good ammount of power just by itself there is no need to push it with more compression
I would Love to Run some C-12 racing fuel in it...... Also trying to boost as High as 30+psi.....Just Undecided with either a 9:1 ariars Pistons or If I can find 8:1 .... CP or WISECO Piston...... With a 100 shot of N.O.S
If they are shelf Wiseco's some people have experienced piston failure in the 650whp region, this is the reason why I am tearing down my motor, I run shelf Wiseco's and it has me kind of worried.
the only problem with shelf pistons at high power is the wrist pins... that goes for any mfr.
IMHO there is so much power to be had w/a custom piston especially when you are talking over 600hp, that I would never build a 600+ hp motor with any shelf piston.. spend the 150-200bux and get a custom unit.
for a typical 600hp build I'd use shelf wiseco's w/upgraded pins. that will handle whatever you want for the most part. If i think it will be going more than 650 its gona be custom.
The shelf Wiseco has a different design than other pistons like JE and CP, I created a thread about it a few months ago, it is a lighter design piston and good for budget builds. Both Jeff Evans and Tony1 have had these fail prematurely in the 600hp region, I dont remember exactly why but I think the failures were in the wrist pin area and not due to the wrist pin by itself. I never intended to take my setup to where it is now, so I ran with the cheaper Wiseco.
What is wrong with a shelf CP for 600hp or even 750hp? I dont see what needs to be custom other than HD wrist pins which is just an option. What would you recommend to be custom when ordering such a piston? I have gone back and forth for a while now with CP's custom piston rep, and if there are some good idea's in piston design I would like to implement them into my new pistons, as it is now I have to order a custom set due to some tight clearances.
when the wrist pin flexes, so does the piston, causing a failure in the pin area....
there is nothing "wrong" with any shelf design, however, there are changes that can be made to the piston that will dramatically increase longevity, power and efficiency. The benefit at lower power levels dosnt really justify the cost for a lower power setup, but with big power 5% is a lot.
any shelf piston w/good pins, race gas and a proper tune will hold damn near whatever power you want it to.
noone is going to give away their custom piston designs.
Oh trust me I had a problem with spending $1500 on a turbo
twice actually my first one cooked in 1500 miles.
I didnt ask for someones piston design, just some idea's on what would make a piston better than a shelf unit.
twice actually my first one cooked in 1500 miles.I didnt ask for someones piston design, just some idea's on what would make a piston better than a shelf unit.
different dish design, different ring pack, skirt type, gas ports, ring position, etc, etc........
