Need help Bov not Blowing off.
Old May 13, 2012 | 07:22 AM
digitaldetox's Avatar
Default Need help Bov not Blowing off.
Turbo 00 Si stock b16. blow off valve line hooked up to manifold vacuum. has vacuum guage reads about 30. tryed while boosting 10psi also 5 psi does not blow off at all. all i hear is a loud surge. anyone have any ideas? screw on bov is set to softest it can go. its a greddy knock off.
Old May 13, 2012 | 07:30 AM
hondad6's Avatar
Default Re: Need help Bov not Blowing off.
Problem "It's a greddy knock off" Try to never skimp on turbo parts. Your motor depends on it.
Old May 13, 2012 | 07:31 AM
Whiterice-gsr's Avatar
what line are u using for vacuum?
Old May 13, 2012 | 07:37 AM
why post if your not gonna post help. its a greddy knock off becuase my mommy and daddy dont buy all my parts for me. anyway. whiterice what do u mean? what size line or which line? line im using comes off the corner of engine bay tees off on a canister which onehalf goes to cruise control other half goes into manifold but i have it teed where it goes to manifold and have bov and boost gauge on it.
Old May 13, 2012 | 07:45 AM
hondad6's Avatar
A little flaming helps get the point across. If "mommy" and "Daddy" were buying me parts would i be riding a 22 year old CRX? No probably not. Don't get soooo defensive right off the rip.
If the line is getting vacuum, but the valve is not opening, the valve could be defective i.e. the blow off valve. try to pull a vacuum on the line and see if it opens manually.
Silvertc's Avatar
I would start by checking for any vacuum leaks. If there's none, take the bov line and run it straight to the intake manifold vacuum port, and see if that makes the bov work.
Old May 13, 2012 | 08:05 AM
i would start by teeing off the brake booster line and seeing if that works before u try anything else.
Old May 13, 2012 | 08:11 AM
should it be open at idle under 30lbs of vacuum?
Old May 13, 2012 | 08:20 AM
mine will if its very cold and the idle is 2500 rpm or so. just pulling the throttle open while under the hood u should be able to see some movement on the softest setting. tee off the brake booster line man start there, then u know u at least have adequate vacuum.
Old May 13, 2012 | 08:44 AM
dpetro1's Avatar
If a better vac source doesn't work, then I would open it up and take a look at the diaphragm.
Old May 13, 2012 | 09:35 AM
^^^ x2
Old May 13, 2012 | 10:04 AM
TravisBiggie's Avatar
pics ...
Old May 13, 2012 | 11:26 AM
SiRCiviC94's Avatar
Yes the mommy and daddy. We all can only wish silver surfers and type r engines came from their pocket lmao.
Now your valve. Take it all apart and reassemble with some oil... Just a bit. If everything appears to function freely hook it up
To the brake booster
With a T.
If no blow off ditch it. I spent about 5 mins trying to get my fake to work and decided *** that it was so cheaply
Made.
Get blitz or apexi. Too many hks and greddy fakes
Old May 13, 2012 | 12:28 PM
i have a turbo xs rfl, cheaper valve but functions well. u can also go tial which is obviously good quality.
Old May 13, 2012 | 01:36 PM
Aradin's Avatar
Premium Member
Did you hook it up to the right nipple? Some BOVs have two, one to keep it clamped shut under high boost which isn't needed on most setups, and the other is used to actually actuate the valve.
Old May 13, 2012 | 03:26 PM
figured it out. took it apart and they had 2 springs stacked inside each other to make it super stiff. took one spring out and it works perfect now. thanks for the help everyone.
Old May 13, 2012 | 07:50 PM
Garage 808 Hatch's Avatar
was about to post this, I had the same issue on my beater sohc. the 2 springs are just too stiff to open
Old May 14, 2012 | 01:08 PM
red96turbols's Avatar
Hmm, I have a greddy type s. When I hooked it up my old tuner said it was wrong and hook it up to the top port but it surged a lot like that so I googled vacuum diagram for it and had it hooked up right to begin with and switched it back and it worked. Years ago I took it apart and it had two springs, read about the type s boost leaking after fifteen lbs so I modified it to hold the spring rate tighter, even on 6psi and softest setting it operates flawless. Double check your vacuum and put that spring back in or have fun boost leaking. Now it's running 25 psi still no issues.
v.i.gsr
Jul 13, 2011 04:09 PM
dAng! Kris
Apr 6, 2011 12:26 PM
tegon-gsr
Apr 7, 2005 07:02 PM
patdemps
Jun 1, 2004 01:51 PM
greyzone
Jun 28, 2001 12:53 PM
