need help asap please
Old Jun 20, 2009 | 11:01 PM
reddcoupe's Avatar
Default need help asap please
hey whats up guys i got a 96 civic coupe i just swap as a fully built 93 ls sleeved block 9-1 compression with a 96 ls head ported and polished with crower turbo cams my problem is i have been trying to start it for the last couple days i got fuel pressure and spark but it just wont start it cranks over like when the timing belt breaks can some one out please help me i am going crazy
Old Jun 20, 2009 | 11:15 PM
cleansi's Avatar
Default Re: need help asap please
check the timming ?
check the dizzy?
check compression ?
Old Jun 21, 2009 | 06:40 AM
reddcoupe's Avatar
i check the timing used a different dizzy the motor got compression but it just cranks like there is no compressionthere is fuel an d spark whats stoping it from starting
Old Jun 21, 2009 | 07:21 AM
BlakeJ53's Avatar
Check or replace all of your grounds. Any check engine code? Actually jumper it dont just count on the check engine light to kick. How do you know you have fuel and spark? Not trying to call you stupid or anything I just want to know how you checked them. Leak down test?? How many times did you crank the engine when you did a compression test?
Old Jun 21, 2009 | 07:36 AM
reddcoupe's Avatar
i added extra engine an tranny grounds did a fuel pressure test i cranked the engine about 4 times on each cylinder for the compression test the only code i found was the idle air temp but i already corrected that problem i got 1000cc bosch injector someone said it was flooding but i dont think thats the problem it should at least start
Old Jun 21, 2009 | 07:51 AM
BlakeJ53's Avatar
Do you have a base map for those injectors?
When you do a compression test you should always crank the car an odd number of times for a proper reading I.E. 5,7,9
Old Jun 21, 2009 | 07:59 AM
BlakeJ53's Avatar
How does your fuel pump sound? Try a fuel pump flow test. Jumper the main relay:
Then do this. You should have atleast 7.8 ounces in 10 to 15 seconds.
Old Jun 21, 2009 | 08:02 AM
reddcoupe's Avatar
ok i will do the over the compression test my boy has bascially the same setup only with a bigger turbo borg warner s372 with a ls vtec motor i transfered is base map but it still dont work
Old Jun 21, 2009 | 08:42 AM
BlakeJ53's Avatar
This is dangerous but I try it often and it nets good results. I pull the fuel rail and put a towel over the intake manifold then I have a friend bump the starter to make the injectors spray. You have to hold them in ther or they fly out. That will definently tell you if your injectors are working or not. Again this is dangerous so becarful.
Old Jun 21, 2009 | 11:28 AM
reddcoupe's Avatar
well i didnot do but i think they should be working cause when i take out the spark plug there is fuel on them at one point gas was from under the head
Old Jun 21, 2009 | 07:48 PM
reddcoupe's Avatar
come guys i need help im about to sell this car an go buy evo it that fustrating
Old Jun 22, 2009 | 05:02 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Have you checked to see if your dizzy is 180 degrees out of phase? Without getting technical pull it out and turn it 180 then put it back in. Also check your firing order on the cap. Lastly by now your plugs are fouled most likely so pull them and check/replace if needed. Fouled plugs WILL NOT let your motor start.
Old Jun 22, 2009 | 06:40 AM
BlakeJ53's Avatar
I have never delt with an LS before but every other honda motor I have delt with the cam and the distributor will not allow eachother to be 180 off it just doesnt fit. Don't try to sell it yet. Its always somthing so simpe its stupid. When you find it you will think man what an idiot it was right in front of me.
Old Jun 22, 2009 | 07:00 AM
Turbo-LS's Avatar
Who put the cams in? did you adjust the valve lash to specs? .007 for intake and .008 for exhaust on a cold engine for crower turbo cams
make sure yoru timign marks are on for the crank and cams. if the head and block have been decked at all the cam gears should tip forward just a little bit but not a whole tooth.
have you pulled a plug to confirm fuel delivery or your just saying its getting fuel cause the pump is running? did you do the changes in the engine management for the bosch injectors? did you properly enter the dead times for the injectors into the software
what engine management are you running?
xLaziestLa0b0ix
Mar 6, 2012 06:38 PM
tarheelsoldier
Mar 15, 2007 08:46 AM
paRRRker
58
Dec 1, 2005 01:19 PM
cyco
Nov 22, 2005 02:41 PM
krazie1
Oct 29, 2003 10:58 AM
