Whats a good turbo for this set up?
Hi i have a 94 hatch with a GSR b18c swap. I am doing a build at the moment and was wondering what turbo would be good for this set up. i would like to be pushhin at least 400-500 whp on the dyno. but its goin to be a street car. This is my set up so far
81.5mm bore (stock sleeves)
81.5 cp 9.8:1 pistons
havent got rods yet but either manley h beams or eagle h beams
OEM Head gasket
OEM bottem end gasket kit.
ARP head studs
ACL bearings
b16 head.(Getting it soon)
OEM Head gasket
ARP head studs
ACL bearings
Re: Whats a good turbo for this set up?
A Precision SC44 aka .60 trim T3/T04E is the very definition of 4-500whp. With the stage 5 turbine and .63 AR housing you'll hit postive pressure before 3000 rpms and make 475whp on kill.
I think some people in this thread are being a little extravagant.
Moderator
We've used the 75mm exducer of the 57 trim to the stage 5 wheel. This is simply our opinion from the data received from the cars tested, but we felt that the turbocharger suffered from reversion when matched up to that exhaust wheel at over 25psi to even come close to that area of power.. With that in mind, we simply stopped using it after a while on the test cars. Regardless, the compressor wheel just didn't have enough CFM volume to do the 400-500whp that he asked for on PUMP GAS, which was his emphasis.
I don't think the options are extravagant, but the OP has also limited his information to us. Once he/she states a particular budget and more information, we can all narrow down the choices a bit more realistically and responsibly.
Mmm, you've got me there. I stand corrected. I'm not a big fan of pushing knock limit so I usually disregard that sort of thing.
B18C-Hatch
11-14-2002 02:05 PM
