Need help ASAP!! Code 22 b18b non vtec
Old Mar 30, 2014 | 05:33 PM
Civic420life's Avatar
Default Need help ASAP!! Code 22 b18b non vtec
Hello honda techies, I just recently wanted to get into boosting Hondas and I know that boosting on a CEL isn't good at all but the question is.... I'm getting code 22 - vtec pressure switch.. I have a b18b non vtec using a p75 ecu. I need a fix and don't know what to do. I've tried several ways to bypass and no luck :/
Old Mar 30, 2014 | 05:47 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Need help ASAP!! Code 22 b18b non vtec
That isn't possible. The P75 is a non-VTEC ECU, and doesn't look for the VTEC pressure switch. You may have a 20 and a 2. Is it an OBD2 ECU? Is it chipped, socketted, or modified at all?
Post a video of the code, and a picture of the inside of the ECU.
Old Mar 30, 2014 | 07:42 PM
It's obd1. My car is a 94 civic ex coupe but it got an engine swap to the b18b1. I got the ecu socketed and chipped. How do you post videos on here? Sorry I'm kinda new on this site
Old Mar 30, 2014 | 07:50 PM
wantboost's Avatar
Who is Mr Robot?
Yea I'm thinking it's a 20 and a 2, sometimes the blinks can be hard to count... my obd1 accords slow flashes are fast and the fast ones are impossible to count lol, the trick is to watch for the long pause between flashes... that indicates it's counting out a 2nd code.
Old Mar 30, 2014 | 07:55 PM
Well when it blinks it's like blink-pause-blink-pause-blink-blink- blink-blink that's like 24 and there's not a 24 -.-
Old Mar 30, 2014 | 08:16 PM
http://s1291.photobucket.com/user/Pe...tml?sort=3&o=0 my chipped p75 ecu.
Old Mar 30, 2014 | 08:36 PM
https://www.youtube.com/watch?v=xAtW...ature=youtu.be video of the CEL LIGHT
Old Mar 30, 2014 | 09:10 PM
h22apwrd95's Avatar
Originally Posted by Civic420life
Code 10 & 14
Old Mar 30, 2014 | 09:36 PM
Wdpfreak145's Avatar
Originally Posted by h22apwrd95
Code 10 & 14
Which would be "IAT" and "IACV" respectively. Make sure you don't have the connectors swapped? Idk about the H22 but IIRC the IACV and IAT sensors on my d16 both have very similar plugs on the engine harness.
Old Mar 31, 2014 | 01:39 AM
wantboost's Avatar
Who is Mr Robot?
Yea the plugs could be swapped, they are basically the same
Old Mar 31, 2014 | 04:19 AM
I'll try that when I get back from Nashville and let you know if it fixed
Old Mar 31, 2014 | 03:43 PM
Ok ya they were backwards code 10 is gone but still have 14 and I tried cleaning it.
Old Mar 31, 2014 | 04:21 PM
It was idling perfectly when they were switched and not it's freaking fluctuating idle like in the 1500rpms
Old Mar 31, 2014 | 04:29 PM
NotARaCist's Avatar
1500 is not proper idle. Reset your idle correctly, and your IACV code might just go away.
Old Mar 31, 2014 | 04:37 PM
Sounds like the IACV is still messed up. Pull it off, soak it in brake parts cleaner, and while it's filled with fluid get in there with some q-tips and clean the buildup off of the plunger. It will work great.
Take a look at your FITV too if you have one and turn the plunger back in a couple threads.
Old Mar 31, 2014 | 05:06 PM
I cleaned both. Fitv is perfect. When I had the IAt and iacv connectors backwards it ran perfect but got CEL's for both, switched them back and IAt code went away but now still have code 14 and now it's fluctuating idle at 1500rpms. I don't get how stuff being backwards made it run right and plugging it up correctly makes it run stupid.
Old Mar 31, 2014 | 05:35 PM
So I unplugged the iacv jumped the connector with a paperclip and the light went off when I reset the ecu. I started the car idles perfectly, light stayed off for like 5 seconds then came back on for code 14. Broken iacv possible?!?
Old Mar 31, 2014 | 07:42 PM
Probably not. You have to realize that when you had the plugs backwards, your iat plug was supplying voltage to the IACV and looking for a return signal voltage. and your IAT was being fed voltage based on startup conditions from the IACV plug. In that case neither will work. Your idle is fluctuating because the iacv can't find a spot that works. Either that, or your coolant is low and air is in the system (stuck in the water ports of the IACV) which is causing it to read funny). Check/bleed coolant, or possibly try switching the IACV out with a known working one to rule it out. They rarely go bad though...
Also, when I had my IACV unplugged it was mostly noticeable in decel, otherwise it's function isn't all that noticeable. But it does matter, believe me.
Old Mar 31, 2014 | 09:02 PM
wantboost's Avatar
Who is Mr Robot?
Unplug the iacv and check base idle, it should be around 800-900rpm with the plug removed.. plug the iacv in and reset the ecu. code should go away, if it doesn't the iacv is bad and needs to be replaced
nkcalvert09
Jun 12, 2011 04:27 PM
nus_dogg
Oct 30, 2010 09:40 AM
ITR0950
Oct 18, 2007 10:10 AM
1SIKCRX
Jul 6, 2005 08:26 AM
ek9800
Apr 4, 2005 12:42 AM
