NEED HELP ASAP!
Old Sep 26, 2001 | 02:55 PM
Mr. Vapor's Avatar
Default NEED HELP ASAP!
ok once again i am having fuel problems....
Ok it goes like this. YOU CUT THE LINE between your fuel rail and your fuel filter approx 1 1/2" from the filter (DONE)
Install supplied addapter and line to 1 1/2" side and connect to fuel filter (done)
install aux fuel pump to two open ended lines and complete the circuit and mount to AC line next to shock tower. (PROBLEM!)
the line coming off the Fuel rail is not long enough so i need a longer line...if i put another adapter in i have been told it wont hurt the flow of fuel since it will change the ID of the line..........where can i get a fuel line (about 10" or so, and the barbed connector) at 7pm on a weds night!!!!
Old Sep 26, 2001 | 02:58 PM
DragII's Avatar
25 Year Member
Default Re: NEED HELP ASAP! (NYb16)
no where unless you have a pep boys, or track auto...you need fuel injected fuel hose..they are stronger than your garden variety fuel hose
Old Sep 26, 2001 | 03:08 PM
dbman96's Avatar
New User
Default Re: NEED HELP ASAP! (DragIIcivic)
Most hardware stores actually sell high pressure fuel injection hose (although home depot doesn't, Ace hardware and OSH seem to carry it most of the time); you can add another two-ended barb fitting to extend it without creating a very large pressure drop; you can find all the barbs and hose clamps you need in the pneumatic tool section.
EK FLY
Jan 6, 2006 05:04 PM
SETI20
May 26, 2005 12:02 AM
Arturbo
Feb 5, 2002 04:05 PM
