need help?! aebs head stud torque specs
i tried the search only showed up 3 post didn't help at all
i know the stud itself has a torque spec....then the actual nut has a torque spec too....help would greatly appreciated trying to finalize my swap by puttin my head on
thanks again
thanks again
its a b18c1 gsr block...with type R head...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">I don't want to insult your intellegence, but have you called AEBS themselves to get info? Ben has the information available to you..</TD></TR></TABLE>
nope i haven't called aebs that why i posted on honda-tech.com knowin someone here had to install these b4 and have the info on hand....
thanks now i just need the specs for the actual nut
I FINALLY GOT THE INFO...
stock factory pre-stage(first stage)
stock factory is 64ft/lbs
aebs
10ft/lbs for the actual stud
then 30ft/lbs pre-stage
then 64ft/lbs
thanks to redz0ne performance
hopefully this helps anyone else in the future...
btw these specs were used on my friends gsr motor and my type R motor
aebs
then 64ft/lbs
Guest
Posts: n/a
Since we are on the subject of head studs. I have some ARP head studs. Have the head off, have the nuts off. What I want to know is how exactly you get the studs out of the block? I know it has the hex on the top, and I tried using an alan wrench to get it out, but that beast is stuck in there.
Any special way to get these out? Thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Since we are on the subject of head studs. I have some ARP head studs. Have the head off, have the nuts off. What I want to know is how exactly you get the studs out of the block? I know it has the hex on the top, and I tried using an alan wrench to get it out, but that beast is stuck in there.
Any special way to get these out? Thanks guys</TD></TR></TABLE>use an allen socket thats what i did...i went to sears and got craftmen 3/16 socket allen worked like a charm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic »</TD></TR><TR><TD CLASS="quote">damn only 1 off </TD></TR></TABLE>
good stuff....thanks for helpin tho...
good stuff....thanks for helpin tho...Thread
